Urgent help! How to link personal libraries?
Like Tree2Likes
  • 1 Post By MartinB
  • 1 Post By MartinB
Old   May 25, 2011, 03:49
Question Urgent help! How to link personal libraries?
Gian Maria Di Stefano
Gian Maria is on a distinguished road
Hello foamers,
my name il Gian Maria. I'm a new user of OpenFOAM, and I need some help to continue my master thesis project.
My aim is to simulate some cases of a thermal energy storage, made by a tank filled of rocks. Hot air is pumped in this tank, and flowing throw rocks the air lose his enthalpy to give it to the rocks.
Up to now I have used the pre-compiled solver called 'rhoPorousMRFPimpleFoam', with 'MRF' zones not abilitated, to calculate the pressure fall in porous zone (I have modelled rocks as a porous zone).
But now I must implement a model to estimate heat exchange between air and rocks. I made it, and I have insert new subfunction in porousMedia files. Then, I have re-compiled 'porousZone' library typing
>> wmake libso
So I have a new library called 'myLib'.
But when I try to compile my solver, OpenFOAM write to output that it doesn't find my new library. I have insert in >>make\options this line:
EXE_USER_LIBS = \
-lmyBCs
Can anybody help me to find my mistake? I don't know how to link correctly my new library.
Thank in advance
Gian Maria is offline   Reply With Quote
Old   May 25, 2011, 05:14
Martin
MartinB will become famous soon enough
Hi Gian Maria,
you can try to these lines into your Make/options file:
EXE_LIBS = \
-L$(FOAM_USER_LIBBIN) \
-lmyBCs
The L$(FOAM_USER_LIBBIN) must point to the location where your myBCs.so resides.
Martin
Bahram likes this.
MartinB is offline   Reply With Quote
Old   May 25, 2011, 05:46
Hi Martin, thanks for your quickly response.
Now I'm trying to make "programming tutorial" from Tommaso Lucchini to learn how to modify the solvers.
These are the slides -> http://goo.gl/UVgjJ
When I add the line 'rampedFixedValueFvPatchFields.C' (slide #40) in icoFoamRamped/Make/files all goes good.
But I want to link a pre-compiled library. So i compile the library with 'wmake libso' command, and I have no problem.
The file generated, libMyBCs, is located in
'home/gimmo/OpenFOAM/gimmo-1.7.0/lib/linux64GccDPOpt'
But if I try to write in icoFoamRamped\Make\options, as you suggested
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
EXE_LIBS = \
-lfiniteVolume \
-/home/gimmo/OpenFOAM/gimmo-1.7.0/lib/linux64GccDPOpt \
-libMyBCs
when I try to compile OpenFOAM gives me this response:
g++: unrecognized option '-/home/gimmo/OpenFOAM/gimmo-1.7.0/lib/linux64GccDPOpt'
/usr/bin/ld: cannot find -libMyBCs
collect2: ld returned 1 exit status
make: *** [/home/myName/OpenFOAM/gimmo-1.7.0/applications/bin/linux64GccDPOpt/icoFoamRamped] Error 1
I have the same problem if I write
'-lMyBCs' instead of ' -libMyBCs'
Any suggestions?
Thanks in advance
Old   May 25, 2011, 06:47
Martin
I think there is a "L" (big letter 'el') missing in front of your path, it should be:
-L/home/gimmo/OpenFOAM/gimmo-1.7.0/lib/linux64GccDPOpt \
Martin
gimba86 likes this.
Old   May 25, 2011, 07:19
Hi Martin!!!!
Thanks a lot for your help!!!! Now it works!!!
I have correct the option files, and now the tutorial case goes good.
I'll try to my case.
Old   September 13, 2022, 08:38
Dcn
Dcn is on a distinguished road
can some one please tell me why in
/OpenFOAM/OpenFOAM-v1912/applications/solvers/incompressible/simpleFoam
in this directory if i execute the command
wmake
why does it gives the error as shown below :=
In file included from simpleFoam.C:32:0:
/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/cfdTools/general/include/fvCFD.H:7:20: fatal error: fvMesh.H: No such file or directory
#include "fvMesh.H"
compilation terminated.
make: *** [Make/linux64NvccDPOpt/simpleFoam.o] Error 1
simpleFoam is not able to recognise the header file fvMesh.H
Dcn is offline   Reply With Quote
porous compile library
OpenFOAM sub-forum link seems to be damaged wyldckat Site Help, Feedback & Discussions 1 September 12, 2010 04:58
Can't profile shared libraries rsamuel OpenFOAM Programming & Development 1 August 3, 2009 09:58
Installation/Tutorial - libraries not found (blockMesh) bernarde OpenFOAM 3 June 19, 2009 12:36
ReleaseNotes13 website link problem maka OpenFOAM 2 November 22, 2006 04:32
Fortran90 (creating executable by using libraries) Ravi Main CFD Forum 0 September 27, 2004 22:34
