Loading V from different directory
Old   November 25, 2015, 11:33
Default Loading V from different directory
yeharav is on a distinguished road
Hi All,
I am trying to load the velocity field from a different directory.
I wrote :
volVectorField U1
IOobject
"U",
otherpath + runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
mesh
Where otherpath is "../../blahblah/".
This worked for a while but now I get error
word::stripInvalid() called for word ....blahblah
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
For one server with OF-2.2.2.
(I have it installed on 3 different servers, and on the other two it worked, so far).
I also tried to write :
word path = "../../blah";
in the code, but I get the same error.
Any thoughts?
Thanks.
yeharav is offline   Reply With Quote
Old   November 29, 2015, 02:54
I still don't know why it suddenly happened but I found a work around.
fileName fullfilename = word(basepath+runTime.timeName(),false);
volVectorField tmpU(IOobject("U","", fullfilename, mesh,IOobject::MUST_READ), mesh);
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
