Some cells have disappeared
Old   December 9, 2010, 08:42
Default Some cells have disappeared
Markus Weinmann
cfdmarkus is on a distinguished road
Hi all,
I have added two lines to pisoFoam to count the number of cells:
const cellList& cells = mesh.cells();
Info << " no cells: " << cells.size() << endl;
When I run it on a single processor it counts: 1278060 cells - which is correct.
But when I decompose the case and run it on 16 processsors, the number reduces to: 79043 cells. This is approx. 1/16 of the total number of cells.
Consequently, when I loop over all cells using "forAll(cells,cellI)" some cells are always missing
Does anyone know why mesh.cells() does not include all cells when run in parallel and how can the missing cells be accessed?
Thanks
Markus
cfdmarkus is offline   Reply With Quote
Old   December 9, 2010, 09:14
Martin
MartinB will become famous soon enough
Hi Markus,
you must gather the information to the master:
label nCells = 0;
nCells = cells.size();
reduce(nCells, sumOp<label>());
Info << " no cells: " << nCells << endl;
Martin
MartinB is offline   Reply With Quote
Old   December 10, 2010, 11:37
Markus Weinmann
Thank you Martin!
Old   August 19, 2011, 08:48
Default field manipulation with parallel computations
Kim Yusik
impecca is on a distinguished road
Thanks for the thread on this subject first.
I've managed to get number of cells in parallel computing as Martin suggested but I still have a problem with modifying 'field' itself. here is the code I use
label nCells = 0;
nCells= cells.size();
scalar i = 0;
forAll(cells, celli){
i++;
Info<<"i= "<<i <<nl;
Info<<"nCells= " <<nCells<<nl;
with a single processor, it shows:
i= 336000
nCells= 336000
with 4 processors, it shows:
i= 84332
nCells= 336000
as you can see, nCells isn't affected by multi processing but the field loop number (i) is depending on the number of processors. So question is that is there any way that I can manipulate field (say velocity) with the parallel compuations ?
What I want to do is imposing artificial fluctuations on one plane in the middle of domain.
I also wrote same question in this forum but no response so far,
http://www.cfd-online.com/Forums/ope...mputation.html
Thanks in advance
Yusik
impecca is offline   Reply With Quote
Old   August 19, 2011, 08:58
Martin
Hi Yusik,
you can manipulate the field within the loop:
i++;
// your manipulation here, each processor will manipulate
// its part of the field.
Hmmhhh, not sure if I understand your problem correctly, maybe you can provide some code snippets of your intended algorithm...
Martin
Old   August 21, 2011, 09:23
Kim Yusik
Yes, it works. you are right Martin. I was a different problem. I replied to other thread (link below). Thanks for your help.
http://www.cfd-online.com/Forums/ope...tml#post320892
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
