Problem adding rhoPhi
Like Tree1Likes
  • 1 Post By Azur
Old   August 7, 2013, 05:46
Default Problem adding rhoPhi
haze_1986 is on a distinguished road
I am trying to solve this:
fvScalarMatrix SEqn
	fvm::ddt(rho,S)
	+ fvm::div(rhoPhi, S)
	- fvm::laplacian(DT, S)
I need to add in rhoPhi in createFields.H, I used the code from interFoam as below:
    Info<< "Reading field rho\n" << endl;
    volScalarField rho
        IOobject
            "rho",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
	mesh
    surfaceScalarField rhoPhi
        IOobject
            "rho*phi",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        rho*phi
There is an error with compilation:
createFields.H:90: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricField(Foam::IOobject, Foam::tmp<Foam::Field<double> >)’
/opt/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GeometricField.C:653: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::wordList&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh]
Would appreciate if anyone can enlighten me on what went wrong. Will provide more info if needed. TIA.
haze_1986 is offline   Reply With Quote
Old   August 7, 2013, 10:34
Michael Ranft
Azur is on a distinguished road
In your case rho is a volScalarField while in interFoam rho1 is a dimensionedScalar.
You can't multiply a surfaceScalarField (phi) with a volScalarField (rho). For a volScalarField all values are defined at the cell centres and for surfaceScalarFields at the face centres of each cell.
So you first have to interpolate the centre values of the rho field to the face centres.
Afterwards you can multiply phi with this new rho field:
    IOobject
        "rho*phi",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    linearInterpolate(rho) * phi
or as ist is done in compressibleInterFoam:
        IOobject
            "rho*phi",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        fvc::interpolate(rho)*phi
The difference between linearInterpolate(rho) and fvc::interpolate(rho) is explained in:
http://openfoamwiki.net/index.php/Op...eInterpolation
Saturne_User likes this.
Azur is offline   Reply With Quote
Old   August 7, 2013, 10:55
Thank you very much, fixed.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
