Heat and Moisture solver - Neumann time varing BC
Old   August 6, 2013, 10:44
Default Heat and Moisture solver - Neumann time varying BC
Richard
Ricardo is on a distinguished road
I would like to write solver for Heat and Moisture transfer in material, but I have problem with boundary conditions. I am using groovyBC to calculate heat and vapour flux on boundaries, but for moisture field it causes stability problems in results.
I can not find problem, but I am thinking about orders of number, heat gradient is in 1e01 but vapour gradient is in 1e-10
Heat transfer flux is obtained from q=alpha*temperature_difference (alpha values from 5 to 30) temperature difference less then 10 Kelvins.
Vapour flux is obtained from q=beta*partial_pressure_difference (beta about 1e-10, partial pressure difference less than 800Pa)
It works for steady state for Dirichlet and Neuman boundary condition.
Where could be a problem?
Thanks
Richard
Ricardo is offline   Reply With Quote
Old   August 6, 2013, 14:13
Smile
Richard
Please delete this topic, problem was not in solver...
I used wrong aproximation of sorption curve (dw) in fvm::ddt(dw,F)... and it caused oscilation of solution
Thanks
Richard
Coupled heat and moisture transfer in porous Mike FLUENT 1 May 4, 2004 12:05
