ground area
Old   January 11, 2012, 10:16
Default ground area
Kathrin
Katl is on a distinguished road
How can I get the horizontal area of a cell?
As far as I know does magSf() give you the vertical face area. Or is there any way to indicate the direction of the cell face vector?
I need this value in order to get the ground area of the cells at a patch. Another option would be deviding the volume of the cells by the cell hight. But I couldn't find a way to get this value either.
Thanks...
Katl is offline   Reply With Quote
Old   January 12, 2012, 11:35
David Gaden
marupio is on a distinguished road
magSf() gives you the magnitude of surface area... Sf() gives you the area vector, pointing away from the owner cell. Get a unit vector of your "ground" surface, pointing up, and dot product the Sf()... I think that should do it.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   January 19, 2012, 09:54
Kathrin
Thanks David for your reply.
I finally went back to my case and tried your suggestion. The thing is just that the ground is perpendicular to the patch so the dot product becomes zero.
I did it like this:
scalar groundArea = gSum( normalVector & patch().Sf() );
cheers
Old   January 19, 2012, 10:17
David Gaden
Oh, sorry, I thought you wanted to find the projected area of a single surface on to the ground. You want the projected area of the entire cell volume? Well, you could do what I suggested for all its bounding surfaces, sum the answers and divide by two. This would work assuming the surfaces overlap only once, which is the case for tetrahedral and hexahedral cell volumes.
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Mesh of the ground of a certain area samiam1000 Main CFD Forum 2 August 5, 2011 01:46
Mesh of the ground of a certain area samiam1000 OpenFOAM 0 August 4, 2011 02:33
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
