Representing controlDict information using OpenFOAM classes
Old   March 26, 2010, 17:11
Default Representing controlDict information using OpenFOAM classes
sanatan is on a distinguished road
What are the OpenFOAM class/API methods to define the information in the controlDict file under the system folder of the root case structure? I would like to define the simulation control information programmatically using the OpenFOAM API.
Once I have defined all the simulation control information, I can choose to either write it out to the root case structure or feed it to OpeFOAM programmatically (using API calls).
How can I accomplish this?
Thanks.
sanatan is offline   Reply With Quote
Old   March 26, 2010, 17:18
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Well, first I have to confess I'm not exactly sure what you want to do!
If you are talking about API as an interface to some kind of your own software, maybe you should get in touch with the guy from http://www.discretizer.org/
He is doing a project called Discretizer::Setup which is feeding the OpenFOAM solver from his meshing software. Maybe this is a hint ...?!?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 27, 2010, 13:27
OpenFOAM has an extensive API and data structures to reperesent flow simulation information. I just need to know how to represent the information in the controlDict file using OpenFOAM.
If my earlier question is not clear then another way to ask the same question is when OpenFOAM parses a case what are the classes/data structures it uses to load the information in the controlDict file into memory?
The reason for my question is that I want to prepare and run the simulation programmatically instead of using the manual steps.
Thanks,
Sanatan
Old   March 27, 2010, 14:20
sega's Avatar
Sebastian Gatzka
Ok, I have really no idea what you are talking about.
But this is due to tha fact that I don't have that much programming experience.
Maybe you can check the Doxygen and look up the source code of some solver to get a feeling how it will access the dictionaries.
(If that is what you are talking about - which I'm not sure of.)
Good luck.
Old   February 28, 2012, 06:46
Bernhard Linseisen
Linse is on a distinguished road
Though late, but maybe it helps...
Did you already check how the information from groovyBC gets into the simulations? For this you add a line within the controlDict and everything works fine.
Thus, maybe looking for the interconnection groovyBC-controlDict does give any further hints on how to achieve your problem?
Linse is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
information about moving mesh in openfoam sambatra OpenFOAM Running, Solving & CFD 2 March 26, 2009 11:16
Problems in representing convected derivatives in OpenFoam titio OpenFOAM Running, Solving & CFD 1 February 16, 2009 15:01
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
