Problems using reconstructPar on a case involving AMI
Like Tree10Likes
Old   April 24, 2012, 02:46
Default Problems using reconstructPar on a case involving AMI
Onno
Kaskade is on a distinguished road
Hello.
I've set up a case using 3 AMIs and MRFSimpleFOAM. It runs fine on one processor, it even runs fine on multiple processors. But I am running into trouble when I try to piece it back together after a parrallel run.
Create time
Create mesh for time = 100
Time = 100
Reconstructing FV fields
    Reconstructing volScalarFields
        p
AMI: Creating addressing and weights between 1628 source faces and 1071 target faces
--> FOAM Warning :
    From function AMIInterpolation<SourcePatch, TargetPatch>::checkPatches(const primitivePatch&, const primitivePatch&)
    in file lnInclude/AMIInterpolation.C at line 146
    Source and target patch bounding boxes are not similar
    source box span     : (8.5e-10 0.55 0.55)
    target box span     : (1.07e-09 0.0576107 0.238538)
    source box          : (0.0423665 -0.275 -0.275) (0.0423665 0.275 0.275)
    target box          : (0.042366 0.217361 -0.136582) (0.042366 0.274972 0.101956)
    inflated target box : (0.0300962 0.205091 -0.148852) (0.0546358 0.287242 0.114226)
--> FOAM FATAL ERROR:
Unable to set source and target faces
    From function void Foam::cyclicAMIPolyPatch::setNextFaces(label&, label&, const primitivePatch&, const primitivePatch&, const boolList&, labelList&, const DynamicList<label>&) const
    in file lnInclude/AMIInterpolation.C at line 878.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   at cyclicAMIPolyPatch.C:0
#3  Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#4  Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::AMIInterpolation(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&, Foam::faceAreaIntersect::triangulationMode const&, bool) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#5  Foam::cyclicAMIPolyPatch::resetAMI() const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#6  Foam::cyclicAMIPolyPatch::AMI() const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#7  Foam::tmp<Foam::Field<double> > Foam::cyclicAMIPolyPatch::interpolate<double>(Foam::tmp<Foam::Field<double> > const&) const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#8  Foam::cyclicAMIFvPatch::makeWeights(Foam::Field<double>&) const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#9  Foam::surfaceInterpolation::makeWeights() const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#10  Foam::surfaceInterpolation::weights() const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#11  Foam::fvPatch::weights() const in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#12  Foam::coupledFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#13  Foam::cyclicFvPatchField<double>::cyclicFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#14  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::cyclicFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#15  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/reconstructPar"
#16  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/reconstructPar"
#17  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/reconstructPar"
#18  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/reconstructPar"
#19  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/software/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/reconstructPar"
#20
#21
#22
#23  __libc_start_main in "/lib64/libc.so.6"
#24
I used scotch to decompose it, which worked on a previous case, set up analogous to the propeller-tutorial. This mesh however has been generated using ICEM and CFX. My first guess was that OF210 can't handle multiple AMIs, but fusing them using createPatch led to the pretty much the same error. Can anyone point me in the right direction?
Kaskade is offline   Reply With Quote
Old   April 30, 2012, 03:27
Nima Samkhaniani
nimasam is on a distinguished road
maybe you need first use reconstructParMesh for each time step then using reconstructPar
Bernhard likes this.
nimasam is offline   Reply With Quote
Old   April 30, 2012, 04:23
Onno
I'll try but I didn't need to use it before.
I used createPatch to make some patches periodic, which created a polyMesh-Directory in timestep 0. Does this maybe cause problems?
Old   June 23, 2012, 05:32
Onno
Update to OF211 fixed the issue.
Old   June 29, 2012, 10:50
supercommandodhruv
dhruv is on a distinguished road
Did you manage to solve the problem? I am having the same issue in my Geometry.
As suggested by Kaskade, I updated my OF version to 2.1.1, but it is still giving me the same message.
AMI: Creating addressing and weights between 11909 source faces and 12860 target faces
--> FOAM Warning :
    source box span     : (9.4 0 2.729063)
    target box span     : (9.4 0 2.729063)
    source box          : (2.35 3 -2.753594) (11.75 3 -0.02453125)
    target box          : (2.3594 60.6 -2.753594) (11.7594 60.6 -0.02453125)
    inflated target box : (1.869993 60.11059 -3.243001) (12.24881 61.08941 0.464876)
Unable to find initial target face
    From function void Foam::AMIInterpolation<SourcePatch, TargetPatch>::calcAddressing(const primitivePatch&, const primitivePatch&, label, label)
    in file lnInclude/AMIInterpolation.C at line 1009.
In the boundary mesh, the number of faces for the patches which are in cyclic AMI are different. It is strange because, it works for one another case I have, which also has a difference between the number of faces.
Could anyone help me in this regard. I have to have cyclic boundary condition on these patches.
Thanks,
Dhruv.
dhruv is offline   Reply With Quote
Old   June 29, 2012, 12:51
Onno
The difference in the number of faces should not be a problem, since part of an AMIs job is to mediate between meshes with different levels refinement.
Are you sure everything else is set up correctly? CofG, Rotational Axis? Are the meshes really correctly positioned or is there a gap or an overlap?
What did you use to create the mesh?
Old   July 2, 2012, 06:32
supercommandodhruv
Yes, the number of faces should not be a problem, since this is what AMI is used for. For your questions:
1. Where can I find the information regarding the CofG, Rotational Axis, etc.?
2. The two faces in the mesh are at a distance of 9.4 units from each other in the x direction. So, the patches which have cyclic AMI in the boundary file looks like this
Out
        type            cyclicAMI;
        nFaces          12860;
        startFace       5101486;
        faces           ( ( 1 2 6 5 ) );
        matchTolerance  0.0001;
        neighbourPatch  In;
        transform       translational;
        separationVector (-9.4 0 0);
In
        type            cyclicAMI;
        nFaces          11909;
        startFace       5055469;
        faces           ( ( 0 3 7 4 ) );
        neighbourPatch  Out;
        separationVector (9.4 0 0);
3. I am using snappyHexMesh to create the mesh. I also changed the matchTolerance to vary between 1e-05 to 1 to see, if it has to do anything with the tolerance levels, but everytime the same error pops up. Any suggestions?
Regards,
Dhruv.
Old   July 2, 2012, 08:53
Onno
1. In the dynamicMeshDict. I thought maybe something was rotating the wrong way.
2. Why do you have 'faces', 'transform' and 'separationVector' in yours. The last two are for cyclic not cyclicAMI. Mine look like this.
   AMI2
        type            cyclicAMI;
        nFaces          7268;
        startFace       2103511;
        neighbourPatch  AMI1;
        transform       noOrdering;
    AMI1
        type            cyclicAMI;
        nFaces          34254;
        startFace       2110779;
        neighbourPatch  AMI2;
3. In some other thread they solved some problem with their AMI by increasing the refinement of their mesh near the AMI, I think. Maybe SHM is generating a mesh that is not curved enough.
Old   July 2, 2012, 09:27
supercommandodhruv
   AMI2
        type            cyclicAMI;
        nFaces          7268;
        startFace       2103511;
    AMI1
        type            cyclicAMI;
        nFaces          34254;
        startFace       2110779;
Thanks for the reply.
1. The case is stationary. So, I dont have a dynamicMeshDict.
2. I tried removing the faces, and making the boundary file like you have posted above, but still I get the same error.
3. I will now try to refine the mesh better to see if it works
Thanks,
Dhruv.
Old   July 2, 2012, 13:09
Onno
This board can be pretty annoying, since many questions remain unanswered, so I try to be of help.
Could you maybe send a picture of your mesh? What is the shape of the AMI? Just a flat face or a cylinder like in the propeller case?
Old   July 3, 2012, 04:49
Default AMI patches
  #11
supercommandodhruv
Hi Kaskade,
Can you send me your mail ID. I cannot post the picture on the forum.
Thanks,
Dhruv.
Old   January 27, 2013, 15:56
Sherif Kadry
sherifkadry is on a distinguished road
You ever get this problem fixed? I have the same issue
Originally Posted by dhruv View Post
Hi Kaskade,
Thanks,
Dhruv.
sherifkadry is offline   Reply With Quote
Old   March 22, 2014, 07:35
Default cyclicAMI is broken in build 2.3.x-9d0ee4591849
  #13
Pekka Pasanen
zordiack is on a distinguished road
I'm having this exactly same problem and I tried to file a bug report but it wouldn't let me (says Forbidden). I'm running the latest git version 2.3.x so this is definitely not fixed.
I tried to run reconstructPar after successful calculation but it crashes. It has worked just fine before.
I have the same case on another computer with build 2.3.x-4ef1b5eeb58d and if the case is run with this version the reconstructPar is working fine. I tried using the older reconstructPar with the case run with newer version but it gives the same error message, therefore the cyclicAMI is somehow broken in the current git version.
The strange thing is that the calculation runs just fine with the new version and based on the cuttingplanes the results also look fine. Only reconstructing the case is not working.
This is a major bug and I wish it's resolved quickly. Could this have something to do with the commit https://github.com/OpenFOAM/OpenFOAM...d2ccf500140c8?
Reconstructing volVectorFields
        U
AMI: Creating addressing and weights between 6 source faces and 6654 target faces
--> FOAM Warning :
    From function AMIMethod<SourcePatch, TargetPatch>::checkPatches()
    in file lnInclude/AMIMethod.C at line 57
    source box span     : (0.0022143419 0.00319520457 0.001766738)
    target box span     : (0.3591645372 0.04399999883 0.1611334531)
    source box          : (-0.1433046982 0.03092641575 -0.1791014874) (-0.1410903563 0.03412162032 -0.1773347494)
    target box          : (-0.2179735666 -0.00800000038 0.06686654698) (0.1411909706 0.03599999845 0.2280000001)
    inflated target box : (-0.2377788156 -0.02780524933 0.04706129803) (0.1609962196 0.0558052474 0.2478052491)
    From function void Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(labelListList&, scalarListList&, labelListList&, scalarListList&, label&, label&)
    in file lnInclude/AMIMethod.C at line 149.
Last edited by wyldckat; March 22, 2014 at 10:35. Reason: posts made 1h apart in different forums and merged here to keep a "tight" discussion
zordiack is offline   Reply With Quote
Old   March 22, 2014, 08:55
Retired Super Moderator
Bruno Santos
Greetings Pekka,
Originally Posted by zordiack View Post
I would have reported this through mantis but for some reason it keeps saying forbidden.
Try logging out - http://www.openfoam.org/mantisbt/logout_page.php - and then logging back in.
In the mean time, you can try undoing only that specific commit:
foam
git revert 8b9a35d3e261e086c5fa20b55bdd2ccf500140c8
./Allwmake
Best regards,
Bruno
Old   March 22, 2014, 10:07
dkxls's Avatar
Armin
dkxls will become famous soon enough
I cannot comment on your actual bug, but about reporting it.
This "Forbidden" error happens sometimes. For me it occurred mostly when I copy&past larger text/errors logs. Though, I couldn't pinpoint what exactly goes wrong, but happened only 2-3 times.
dkxls is offline   Reply With Quote
Old   March 22, 2014, 12:04
Bruno Santos
For future reference, Pekka has reported this issue here: http://www.openfoam.org/mantisbt/view.php?id=1234
Old   March 22, 2014, 15:52
Bruno Santos
@zordiack: I've finished building the latest OpenFOAM 2.3.x, commit 9d0ee45918 and tried to run the following tutorials:
  • "incompressible/pimpleDyMFoam/mixerVesselAMI2D" - ran Allrun
  • "incompressible/pimpleDyMFoam/oscillatingInletACMI2D" - ran Allrun-parallel
  • "incompressible/pimpleDyMFoam/propeller"- ran Allrun and left it running for a while, stopped and reconstructed it.
And in all of them, everything ran just fine.
It's possible that I'm not using a particular feature that you're using, but since I'm not very familiar with AMI in OpenFOAM, it would be helpful to know which tutorial to test with, to see if the problem is reproducible.
Old   March 24, 2014, 02:38
Pekka Pasanen
The problem was not with AMI, it was groovyBC and swak4Foam. I'm using the development version of swak4Foam and once I commented out the libs in controlDict reconstructPar started working again.
So if you're encountering some weird errors regarding decompose/reconstruct, check your libs for any "nonstandard" libs. It still puzzles me how could it run fine and then not recontruct with the libs.
sahas, wyldckat, callmetao and 2 others like this.
Old   March 21, 2016, 01:31
Joern Beilke
JBeilke is on a distinguished road
The problem was fixed in 3.0.0 but reintroduced in 3.0.x
JBeilke is offline   Reply With Quote
Old   March 26, 2016, 05:01
Bruno Santos
Quick question @JBeilke: Can you please provide more details, namely which tutorial case I can use to test this, so that I can reproduce the problem?
Sample utility problems msrinath80 OpenFOAM Running, Solving & CFD 12 December 21, 2012 05:51
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
Problems involving interFoam and GCC 410 gschaider OpenFOAM Installation 1 July 30, 2006 19:58
Problems reading a case cavity into paraFoam red hat 9 anton322322 OpenFOAM Pre-Processing 0 April 11, 2005 13:13
High speed flow problems Sawa FLUENT 3 January 14, 2003 01:10
