How to let OpenFOAM abort a simulation when values exceed a given range? |
June 29, 2012, 07:01 |
notyet
When the absolute pressure becomes negative or U exceeds the speed of light, things have pretty obviously gone wrong (be that bad boundary conditions, a too coarse mesh, a too large timestep etc.).
So, is there any way to have a simulation abort with an error message when values exceed definable non-physical ranges? -- I also asked this question at the Computational Science StackExchange (http://scicomp.stackexchange.com/q/2654/1669), please have a look at their Q&A system which offers a more ordered system for answers (none of these <<oh, I haz similar prob, plz send codez>> "answers") |
June 29, 2012, 21:45 |
#2 | |
if(max(mag(U)).value()>3e8) { FatalErrorIn("Function name")<<"error message"<<abort(FatalError); } If the velocity exceed 3e8, there should be a problem, and program should abort after a short time itself. Regards, Junwei |
July 2, 2012, 02:10 |
#3 | |
notyet
I assume you mean putting that in the used solver? But is there any other solution that does not require recompilation? Maybe something like a #codeStream statement in controlDict? Cheers |
limits |
particle parallel run crashes - values out of range | heavy_user | OpenFOAM Running, Solving & CFD | 0 | November 2, 2011 12:31 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
Monitor point values in a steady state simulation | Kushagra | CFX | 2 | July 13, 2008 20:03 |
transonic simulation with OpenFoam | Shyam | Main CFD Forum | 0 | June 12, 2008 02:39 |
Numerical values from simulation | Ravi | FLUENT | 0 | February 11, 2003 09:02 |
