July 5, 2012, 16:45 |
Baffle Nozzle Flow Error Help
Rep Power: 14 |
Hi Foamers,
I'm still reasonably knew to OpenFOAM and I was wondering if someone would be able to help me out. I am simulating nozzle flow and the heat transfer across the nozzle wall. I have complied a knew solver, by introducing Baffle to rhoSimpleFoam. I have the following error when running my solver: Error: --> FOAM FATAL ERROR:Any help that anyone could offer would be greatly appreciated. Thanks, Thomas |
July 17, 2012, 17:27 |
Rep Power: 14 |
Hi all,
The error to my problem was the directMappedWall class has been changed in OF2.1.x to mappedWall |
April 16, 2013, 20:14 |
More explanation?
Jeff Cumpston
Rep Power: 14 |
Hi Tomloh,
I'm trying to simulate radiative heat transfer in my OpenFOAM simulation. I am trying to use viewFactorsGen utility. This utility is designed to calculate radiative view factors between surfaces, by only if they have the greyDiffusiveRadiationViewFactor boundary condition set in the 0/Qr file. I know that explanation is very particular to my problem, but I'm trying to set the scene. When I run viewFactorsGen, it gives me the error: Code:
--> FOAM FATAL IO ERROR: patch type 'genericPatch' not type 'mappedPatchBase' for patch cavity_inside_back file: /home/jeff/OpenFOAM_workspace/radiation/0/Qr::boundaryField::cavity_inside_back from line 36 to line 19. From function radiationCoupledBase::radiationCoupledBase ( const fvPatch& p, const dictionary& dict ) in file derivedFvPatchFields/radiationCoupledBase/radiationCoupledBase.C at line 92. FOAM exiting I fall short in my understanding of what a 'mappedPatchBase' boundary is. I think it is a trivial move to change the type in the boundary file. I think the name implies that something has to be mapped, possibly by an openfoam utility, but I don't understand what this mapping is. I will also post this as a new thread, but I thought seeing as you had the same error message, albeit in quite different circumstances, you may be able to provide some insight into the problem. Cheers, Jeff |
February 6, 2014, 05:49 |
#4 | |
ksengupta
Rep Power: 16 |
June 17, 2014, 10:05 |
#5 | |
hyacinthe
please can you help me to resolve my problem when i run the pisofoam i have this error --> FOAM FATAL IO ERROR: patch type 'genericPatch' not type 'mappedPatchBase' for patch inlet of field U in file "home/numeric/OpenFOAM/numeric-2.0.0/run/intership |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
3D-Simulation of Water Flow From Nozzle into Air | Navin Sampath | FLOW-3D | 2 | February 26, 2009 10:46 |
Flow pattern in a Nozzle | sean | Main CFD Forum | 0 | February 2, 2009 04:36 |
NEED HELP! Flow through nozzle vanes with clerance | C K Tang | Fidelity CFD | 2 | July 29, 2003 13:07 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
