OF in parallel on a server
Like Tree3Likes
  • 3 Post By wyldckat
Old   August 3, 2012, 10:12
Default OF in parallel on a server
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am running OF in parallel on a server.
I would like to know how I can put the jobs in background.
Let me show you the steps I do:
1. I write my decomposeParDict and i give the command decomposePar.
2. I create the file machine which contains the file of the server-machine
3. I give the command mpirun --hostfile machines -np 4 buoyantPimpleFoam -parallel > case.log
Now I would like to put the job in BG in order to be able to shut down my laptop. I press Ctrl-z and then bg, but if I digit disown and I shutdown my laptop, the process ends.
What should I do?
Thanks for help,
Samuele
samiam1000 is offline   Reply With Quote
Old   August 3, 2012, 10:20
Retired Super Moderator
Bruno Santos
Try:
foamJob -p buoyantPimpleFoam
This script will take care of the details of using the "machines" file and running in parallel. For more:
foamJob -help
edit: er... well, now I remembered that it keeps a pipe open between the machines... so I'm not sure if it'll continue running...
edit2: I think the only way to be 100% remote, you will have to launch the job from one of the remote machines. This is why there are Job Schedulers for clusters
samiam1000, Mojtaba.a and y_jiang like this.
Last edited by wyldckat; August 3, 2012 at 10:29. Reason: see "edit:" and "edit2:"
Old   August 3, 2012, 10:28
Samuele Z
WoW: it works!
Thanks a lot,
Samuele!
Parallel run on remote server OpenFOAM_user87 OpenFOAM Running, Solving & CFD 2 February 8, 2012 03:43
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
CFD Online Back on Main Server pete Site News & Announcements 0 March 31, 2011 18:14
CFD Online Server Load Jonas Larsson Main CFD Forum 0 March 13, 2001 14:29
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
