Nusselt number correlation problem
Old   September 28, 2012, 17:01
Default Nusselt number correlation problem
mrt
Rick Tejeda
mrt is on a distinguished road
I'm trying to calculate the heat transfer through an enclosure similar to the buoyantCavity tutorial, but my results do not correlate well with literature. For example, the Nusselt number for an argon filled 1m x 1m x 12.7mm cavity with a dT of 29.1 degrees should be about 1.3 according to Wright (www.solarme.uwaterloo.ca/DownloadPDFs/ASHcornScan_acw.pdf), but I'm getting Nu = 1.1 with the attached model. Successive grid refinements don't significantly change the answer I'm getting. I think my problem is either with the BCs or the grid design, but nothing I try seems to help. Any suggestions for improving the correlation would be greatly appreciated.
mrt is offline   Reply With Quote
Nusselt Number problem Goutam OpenFOAM Running, Solving & CFD 5 July 12, 2012 05:14
Problem in Nu number Diana.N FLUENT 2 March 2, 2012 06:18
Local Nusselt Number rohangulavani FLUENT 0 July 6, 2010 07:03
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Nusselt Number of the order of 35000 chinmay FLUENT 4 May 31, 2001 03:06
