Rotating a square between water and air!!! please help me |
October 5, 2012, 15:27 |
Hi everybody
I'm trying to simulate a rotating square between water and air. but when I ran it, whole of my model started to rotate. I want to rotate only the square. I'm using interDyMFoam and my dynamicMeshDict is as follow: Code:
dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { // cellZone z0; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { CofG (1.5 1 0); radialVelocity (0 0 600); // deg/s } } Code:
actions ( { name c0; type cellSet; action new; source boxToCell; sourceInfo { box (1 0.75 0) (2 1.25 1); } } { name c0; type cellSet; action invert; } ); thank you |
October 6, 2012, 13:16 |
hi again,
I approached some success but still there is another error!!! I remove my box from the mesh, so I have just a rectangular. instead I create the box with topoSet: Code:
actions ( { name c0; type cellSet; action new; source boxToCell; sourceInfo { box (1 0.75 0) (2 1.25 1); } } { name c0; type cellZoneSet; action new; source setToCellZone; sourceInfo { set c0; } } ); Code:
1 ( cellZone c0; { // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin origin [0 1 0 0 0 0 0] (1.5 1 0); axis axis [0 0 0 0 0 0 0] (0 0 1); omega omega [0 0 -1 0 0 0 0] 104.72; } ) Code:
dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { cellZone c0; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { CofG (1.5 1 0); radialVelocity (0 0 360); // deg/s } } Code:
MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 12 to 13 to distinguish between timeNames at time 0.00823197 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.322617, Final residual = 0.00186789, No Iterations 2 time step continuity errors : sum local = 4.29278e-35, global = -6.25487e-38, cumulative = -1.63983e-12 GAMGPCG: Solving for p_rgh, Initial residual = 0.00377318, Final residual = 2.5956e-09, No Iterations 7 time step continuity errors : sum local = 7.89155e-41, global = 1.65503e-42, cumulative = -1.63983e-12 ExecutionTime = 11.66 s ClockTime = 11 s Interface Courant Number mean: 1.23621e-14 max: 1.90583e-10 Courant Number mean: 1.71623e-13 max: 0.498603 deltaT = 7.02395e-15 Time = 0.008231967303353 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00823197 transformation: ((0.0537059 -0.0762125 0) (0.999666 (0 0 0.0258586))) Execution time for mesh.update() = 0.03 s time step continuity errors : sum local = 8.40744e-15, global = 1.25511e-32, cumulative = -1.63983e-12 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 6.72386e-06, No Iterations 7 time step continuity errors : sum local = 8.71776e-15, global = 2.16723e-24, cumulative = -1.63983e-12 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.320425, Final residual = 0.00185845, No Iterations 2 time step continuity errors : sum local = 2.11983e-35, global = -3.2799e-38, cumulative = -1.63983e-12 GAMGPCG: Solving for p_rgh, Initial residual = 0.00373144, Final residual = 2.53592e-09, No Iterations 7 time step continuity errors : sum local = 3.82037e-41, global = 8.38953e-43, cumulative = -1.63983e-12 ExecutionTime = 11.97 s ClockTime = 12 s Interface Courant Number mean: 6.19464e-15 max: 9.70649e-11 Courant Number mean: 8.60789e-14 max: 0.499017 deltaT = 3.51889e-15 Time = 0.008231967303356 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00823197 transformation: ((0.0537059 -0.0762125 0) (0.999666 (0 0 0.0258586))) Execution time for mesh.update() = 0.04 s time step continuity errors : sum local = 4.36747e-15, global = -2.00572e-32, cumulative = -1.63983e-12 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 5.83869e-06, No Iterations 8 time step continuity errors : sum local = 4.66468e-15, global = 1.53072e-22, cumulative = -1.63983e-12 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.500578 Min(alpha1) = -3.18487e-13 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.320982, Final residual = 0.00186428, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/interDyMFoam" #5 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/interDyMFoam" #6 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/interDyMFoam" #7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #8 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/interDyMFoam" Floating point exception anybody knows how can I solve this problem? and how can I have a separated rotating box instead of a moving mesh that has no boundary with its surrounding fluids? please help me. thank you. |
October 8, 2012, 02:49 |
anyone has any idea?!?!?!? please.
October 10, 2012, 05:10 |
actually, there is nobody to help me?!! I just want to rotate a square in a fluid.
does the OpenFoam has the remeshing capability? |
October 16, 2012, 06:35 |
Hi Mostafa,
I am not sure if I understand properly what you are trying to do. Could you send some sketch? I would also suggest to check the general grid interface (GGI), which should allow you to rotate the square. Greetings Iván |
October 16, 2012, 10:24 |
#6 | |
Thank you for your reply. I attach you a mesh that I have solved it in FLUENT. I tried ggi before, but I couldn't find it in src or internet. I'm using OF-2.1.0. |
October 16, 2012, 10:46 |
If you are using OF210 you should have a look at AMI, which is very similar to GGI.
GGI is only available in OF1.6-ext (maybe also in OF1.5-dev, I am not sure). Greetings Ivan |
May 15, 2013, 01:45 |
Nima Samkhaniani
Rep Power: 24 |
dear mostafa, did you find why this error happens?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
May 15, 2013, 03:30 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 07:37 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Separation phenomenon of water, droplet and air | Raymond | CFX | 0 | July 9, 2004 22:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
