Running a very large parameter range with OpenFOAM-2.1.x
Old   October 15, 2012, 22:58
Default Running a very large parameter range with OpenFOAM-2.1.x
Nishit Joseph
JLight is on a distinguished road
Hi OF Users!
I want to run a wide range of parameters for a case that I am studying. When using fluent, I used to work with Python to create the journal files put them in seprate directories and then submit the job (work is done on a HPC).
I would like to do the same in OpenFOAM-2.1.x. I have seen some examples in python wrapers called pyFoam now pythonFlu.
Unfortunately I am not able to compile pythonFlu against OF-2.1.x.
The binaries are for python24 which make it tough for me to work on my laptop (to then later submit to the HPC). I use ArchLinux and there is no offical Python24.
Is there any tool that I can use to create OF cases.
Cheers!
Nishit
JLight is offline   Reply With Quote
Old   October 16, 2012, 04:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by JLight View Post
Hi OF Users!
Cheers!
Nishit
Well. If you don't want to modify the solvers anyway then you can use the other PyFoam (which is still called PyFoam). PyFoam can be used for manipulating case files and running the solvers (also analyzing the output of those), it has no compiled parts. But you can't write new solvers like you can in PythonFlu.
For an example on a parameter variation see http://openfoamwiki.net/index.php/Co...eter_Variation (while writing I realised that the example still uses the pre-1.5 convention for utility-calling. But it should give you an idea)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
OpenFOAM 2.1.x - AMI (Arbitrary Mesh Interface) philippose OpenFOAM Running, Solving & CFD 39 March 17, 2017 09:52
Eureka, OpenFoam 1.5 is running on OpenSUSE11.1 Ahmed Main CFD Forum 0 March 7, 2009 22:20
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Running OpenFOAM Sean Main CFD Forum 1 April 8, 2008 13:26
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
