sprayEngineFoam - floating point exception error
Old   December 16, 2012, 13:36
Default sprayEngineFoam - floating point exception error
ris
ri
ris is on a distinguished road
I am attempting to run a simulation using sprayEngineFoam using the standard kiva geometry provided with enginefoam .
I have used the system folder and engine geometry files of enginefoam and the spraycloudproperties/chemistry/thermophysical/combustion files of sprayfoam.
The simulation runs until the point of injection, where after the 1st injection of particles, I recieve the following floating point exception error:
Solving cloud sprayCloud
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 Foam::C7H16:(double, double, double) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libliquidProperties.so"
in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam"
#11
#12
#13 __libc_start_main in "/lib64/libc.so.6"
#14
at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
I have attached my case folder (The geometry is the otape17 kiva file not included in the zip), Please could someone have a look at this and see where I could be going wrong.
Many thanks,
ris.
ris is offline   Reply With Quote
Old   December 17, 2012, 16:07
ris
ri
I managed to overcome the problem. I defined flowrateprofile in seconds rather than CAD which was a silly misatke. Also I increased the number of ncorrectors and switched off momentum predictor.
Old   December 17, 2012, 16:46
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The latest version of sprayEngineFoam has injection defined in terms of CA. But I'm glad you fixed your problems.
mturcios777 is offline   Reply With Quote
Old   May 27, 2013, 07:01
Vijay Bhaskar Devarapalli
vijay480 is on a distinguished road
Hello Sir,
I am new to OpenFoam and i am looking at simulating sprayEngineFoam .unfortunately in my version of OF i dont have any tutorial . Nevertheless I have combined engineFoam and sprayFoam but still couldnot take it ahead.
Any help from people who has done sprayEngineFoam will b ehighly appreciated !
Thanks ,
Vijay.
vijay480 is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
