Tutorial for sprayEngineFoam
Old   October 28, 2012, 13:52
Default Tutorial for sprayEngineFoam
Rui Alexandre Trigo Ribeiro Pereira
ed_teller is on a distinguished road
Hi
I have tried to make a tutorial for sprayEngineFoam, using sprayFoam files for combustion, chemistry and spray definition, and engineFoam for cylinder movement.
I also updated the injecto position description so as to match the cylinde description geometry in engineFoam... everything seems allright, but whan i try to launch sprayEngineFoam, some weird error occurs... can someo ne pls help me here...?
alex@iskandhar:~/OpenFOAM/alex-2.1.x/run/tutorials/lagrangian/sprayFoam/dieselEngine$ sprayEngineFoam
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.x-c1ffc2074f88
Exec   : sprayEngineFoam
Date   : Oct 28 2012
Time   : 20:46:59
Host   : "iskandhar"
PID    : 4955
Case   : /home/alex/OpenFOAM/alex-2.1.x/run/tutorials/lagrangian/sprayFoam/dieselEngine
nProcs : 1
sigFpe : Floating point exception trapping - not supported on this platform
allowSystemOperations : Disallowing user-supplied system call operations
Create engine time
Create mesh for time = -180
Selecting engineMesh layered
deckHeight: 0.085639
piston position: 0
Reading g
Creating combustion model
Selecting combustion model PaSR<psiChemistryCombustionModel>
Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics>
Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>>
Selecting chemistryReader chemkinReader
ODEChemistryModel: Number of species = 15 and reactions = 39
Selecting ODE solver SIBS
Creating component thermo properties:
    multi-component carrier - 15 species
    liquids - 1 components
    solids - 0 components
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Creating field dpdt
Creating field kinetic energy K
Constructing sources
No field sources present
Constructing reacting cloud
Constructing particle forces
    Selecting particle force sphereDrag
Constructing cloud functions
    none
Selecting dispersion model none
Selecting injection model coneNozzleInjection
    Constructing 3-D injection
Selecting distribution model RosinRammler
Selecting patch interaction model standardWallInteraction
Selecting surface film model none
Selecting U integration scheme Euler
Selecting heat transfer model RanzMarshall
Selecting T integration scheme analytical
Selecting composition model singlePhaseMixture
Selecting phase change model liquidEvaporationBoil
Participating liquid species:
    C7H16
Selecting AtomizationModel none
Selecting BreakupModel ReitzDiwakar
Selecting StochasticCollisionModel none
Average parcel mass: 3e-06
Selecting radiationModel none
Courant Number mean: nan max: nan
Total cylinder mass: -nan
PIMPLE: Operating solver in PISO mode
Starting time loop
Crank angle = -179.75 CA-deg
deltaZ = 2.86047e-07
clearance: 0.0856387
Piston speed = 0.0102977 m/s
Solving cloud sprayCloud
Cloud: sprayCloud
    Current number of parcels       = 0
    Current mass in system          = 0
    Linear momentum                 = (0 0 0)
   |Linear momentum|                = 0
    Linear kinetic energy           = 0
    Rotational kinetic energy       = 0
    Total number of parcels added   = 0
    Total mass introduced           = 0
    Parcel fate (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Mass transfer phase change      = 0
    D10, D32, Dmax (mu)             = 0, 0, -1e+21
    Liquid penetration 95% mass (m) = 0
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux:  solution singularity
DILUPBiCG:  Solving for Uy:  solution singularity
DILUPBiCG:  Solving for Uz:  solution singularity
--> FOAM FATAL ERROR:
Singular matrix
    From function LUdecompose(scalarSquareMatrix& matrix, labelList& rowIndices)
    in file matrices/scalarMatrices/scalarMatrices.C at line 60.
FOAM exiting
Best Regards
Alex
ed_teller is offline   Reply With Quote
Old   November 15, 2012, 23:16
u22
Anthony Nitski
u22 is on a distinguished road
Alex, didyou solved a problem? I also try to get sprayEngineFoam working... Can you share your case? My mail is nitskiy.a (at) gmail.com.
u22 is offline   Reply With Quote
Old   November 16, 2012, 12:28
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I would check both the velocity and pressure fields and the timestep. Because you are running multiphysics (fluid + spray), the timestep will need to be smaller. Try setting your starting dT to 0.01, and your maxDeltaT to 0.1. A max Courant number of 0.1 is advisable.
mturcios777 is offline   Reply With Quote
Old   December 25, 2012, 23:51
pushkaraj
pushkaraj is on a distinguished road
hi ed_teller
can you share your spryengineFoam tutorial with me..... im new here n i have no idea how exactly spray simulation works......i tried sprayFoam its not working out.....can you give me easy algorithm to carry out simulations for spray
thanks
pushkaraj
pushkaraj is offline   Reply With Quote
Old   May 27, 2013, 07:03
Vijay Bhaskar Devarapalli
vijay480 is on a distinguished road
Hello ,
Has anyone solved the problems associated with sprayEngineFoam ?
Please reply !
Cheers,
Vijay.
vijay480 is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 16:01
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
