DES in OpenFOAM
Like Tree4Likes
  • 4 Post By Budlo
Old   March 17, 2009, 07:46
Default DES in OpenFOAM
Sven Degner
sven82 is on a distinguished road
i find the spallart allmaras modell in the LES case,
its the equals DES?
The coeffs look like DES, with CDES in the LESProperties !
best regards
sven82 is offline   Reply With Quote
Old   March 10, 2010, 00:18
Default How to set up DES simulation in OpenFOAM-1.5
Mahendra
mahendra is on a distinguished road
hello everybody
I am looking for setting up a DES simulation, I was wondering if it is similar to LES (LESProperties). Do we need a file DESProperties in /constant and use the oodels code to run it.
Can anyone please let me know how to set up a DES simulation.
Thanks and Regards
Mahendra
mahendra is offline   Reply With Quote
Old   March 10, 2010, 07:32
Sandy Lee
sandy is on a distinguished road
I guess, we just need to add RANS model as the wallfuctions to LES, right? Who can give some light?
sandy is offline   Reply With Quote
Old   March 14, 2012, 05:41
Default Des
namdar
Budlo is on a distinguished road
Hi FOAMer
When we use RANS (Spalart_allmaras) with LES It show that we use a hybrid method. common hybrid method is DES that proposed with Spalart. In OpenFoam when we choice the Spalart in LES It show that we use from a DES method. We first must study about LES then About DES to work correct with it in OpenFoam. Two good references for this two step are :
1- Computational Fluid Dynamics, J.Blazek, Second Edition.
2- Trailing Edge Noise Simulations using IDDES in OpenFOAM, Master of Science Thesis, Olivier Verhoeven, 2011.
Budlo is offline   Reply With Quote
Old   March 14, 2012, 05:47
Default DES in OpenFoam
namdar
Hi FOAMer
DES is a method that use RANS at the near wall and Use the LES at the far from Wall. the Cost of computational in this method is lower than pure LES but have a good accuracy. So It is a good choice for Industrial application.
Old   November 8, 2012, 11:36
hewei is on a distinguished road
Originally Posted by Budlo View Post
Hi FOAMer
Hi Budlo,
I tried to choose the LES with SpalartAllmarasIDDES model, is it the hybrid Rans/Les method? how to set the boundary condtions in the 0/ folder, i.e. nuSugs. Do you have some cases about IDDES simulation? thank you!
yours,
Wei
hewei is offline   Reply With Quote
Old   November 27, 2012, 04:42
namdar
Hi Hewei
The best tutorial and example for IDDES in OpenFoam is :"Trailing Edge Noise Simulations using IDDES in OpenFOAM" by Olivier Verhoeven ,2011.
All the best
Namdar Budlo.
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
Ibd like to know if OpenFoam is able to do this cocaaladioxine OpenFOAM Running, Solving & CFD 1 May 29, 2006 16:34
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
