[swak4Foam] Velocity waveform with groovyBC
Old   December 5, 2012, 13:08
Default Velocity waveform with groovyBC
bryan
bcgooder is on a distinguished road
I am trying to use the groovyBC boundary condition on my inlet with a velocity waveform text file. The waveform file contains an experimentally recorded velocity magnitude at every time point. Is there a way to do this with groovyBC or is there a better boundary condition to use to apply these velocity magnitude values normal to the inlet patch?
Thanks.
bcgooder is offline   Reply With Quote
Old   December 5, 2012, 13:34
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Thanks.
Is the velocity magnitude only a function of time U(t) or also of the place (on the inlet) U(t,x). The first one can be done with timelines in groovyBC ... the second one not easily
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   December 5, 2012, 13:36
bryan
The velocity magnitude is only a function of time.
Old   December 5, 2012, 13:45
Assistant Moderator
Bernhard Gschaider
Then you're in luck. Have a look at the wobbler-case in Examples/groovyBC to see how to use timelines
[swak4Foam] Velocity gradient outlet BC penalisation using groovyBC Hiroshiman OpenFOAM Community Contributions 10 June 11, 2014 16:57
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
Insert inlet velocity waveform Hila Main CFD Forum 0 April 18, 2006 04:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
