[swak4Foam] an error in new groovyBC
Old   December 6, 2012, 11:18
Default an error in new groovyBC
immortality's Avatar
Ehsan
immortality is on a distinguished road
I just compiled new groovyBC 0.2.1 and this error is shown,whats the cause?
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
--> FOAM Warning :
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C at line 262
Reading "/home/ehsan/Desktop/thesis_Central/0/p::boundaryField::left" from line 30 to line 64
expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 59 the string "((0<=time()&&time()<=(y_max-pos().y)/vel_r)||(time_1<=time()&&time()<=time_2)||(time_2< =time()&&time()<=(y_max-pos().y)/vel_r+time_2)||(time_3<=time()&&time()<=time_final ))?0:1"
file: /home/ehsan/Desktop/thesis_Central/0/p::boundaryField::left::valueFraction at line 59.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 91.
FOAM exiting
immortality is offline   Reply With Quote
Old   December 6, 2012, 11:41
Assistant Moderator
Bernhard Gschaider
Create time
--> FOAM Warning :
FOAM exiting
That is not a groovyBC-problem but a PEBCAK (look it up on the forum ): OpenFOAM complains that the value for valueFraction is not a scalar but a string. And it is right: there should be a scalar. The string should go to the entry fractionExpression
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 6, 2012, 12:09
Ehsan
I want when time is in proper value BC be value if not be gradient how should I do this except at valuFraction?
Old   December 6, 2012, 12:14
Assistant Moderator
Bernhard Gschaider
The answer is in my last posting as well as in http://openfoamwiki.net/index.php/Co...s_in_the_patch
The frequency of your questions suggests to me that instead of reading documentation (an there is not THAT much) you prefer asking. Problem with that approach is that people may have stopped answering your questions once you come to the parts that are not in the documentation
Old   December 6, 2012, 12:34
Ehsan
oh there is not something like valueFraction the correct keyword name is fractionExpression.I dont know how this mistake has occured in writing although I have read document several times. however thanks.
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
