how can I apply this BC? please help me
Old   December 16, 2012, 10:50
Default how can I apply this BC? please help me
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
I want to apply this BC to my U:
du/dx=-dv/dy , dv/dx=0
which the u is the x-component and v is the y-component of U.
any body knows how can I define this BC?
any hint will valuable for me.
Thank you.
adambarfi is offline   Reply With Quote
Old   December 16, 2012, 14:01
immortality's Avatar
Ehsan
immortality is on a distinguished road
what shape does your boundary have?is it aligned with x or y axis or any other?
Can't you simplify the formula on the boundary?
immortality is offline   Reply With Quote
Old   December 16, 2012, 14:22
adambarfi's Avatar
Mostafa Mahmoudi
It's not a matter that my bc is horizontal or vertical, I want to know how can I apply such a bc.
Old   December 18, 2012, 06:55
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
Is your problem 2-D? If yes first BC says that div(V)=0 so I think this may be a problematic BC. For the second one I think you can use OF BCs.
ata is offline   Reply With Quote
Old   December 18, 2012, 07:23
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by ata View Post
Hi
ِDear ata,
These conditions are for only one boundary. I want to apply this two conditions for my boundary simultaneously.
yes, I's 2D.
the complete form of my bc is attached.
thank you.
Old   December 18, 2012, 08:40
Joe Nick
joenick is on a distinguished road
without knowing the context of your problem, a good answer will be difficult. Which process do you calculate? What are P, theta, in and out in the attached figure?
Have you tried to reformulate the BC using the PDE that is being solved?
joenick is offline   Reply With Quote
Old   December 18, 2012, 09:26
adambarfi's Avatar
Mostafa Mahmoudi
Thanks Joe,
Assume a cavity that its right wall is open and the conditions I refered above are the conditions at this open side. my solver is buoyantBoussinesqSimpleFoam and as I mentioned above the pressure is P=0 and the theta is the temperature.
What is your meaning of 'reformulation of BC using the PDE that is being solved'?
Thank you
Old   December 18, 2012, 12:12
Joe Nick
I'm afraid I cannot help, because I don't know this solver.
What I mean by reformulating the BC is to make use of the differential equations for U in your solver to simplify your BC. Just a thought.
If you explain why you choose this BC instead of showing only the equation, somebody might be able to help. What are you trying to solve conceptually, not mathematically?
dv/dx=0 seems to make assumptions about the normal direction of the boundary and can't be applicable in general unless you have some anisotropic forces.
Old   December 18, 2012, 12:30
adambarfi's Avatar
Mostafa Mahmoudi
thank you Joe,
As I mentioned in my last post, I want to model an open cavity. this kind of cavities have an open side that have special conditions that I want to model it. I tried to replace it with other boundary conditions and even with a huge space with special BCs that might make my desired BC. but all of them failed.
I will try if can I include this bc in my solver or not!!
Old   December 24, 2012, 08:10
Retired Super Moderator
Bruno Santos
Greetings to all,
Since adambarfi sent me an email the other day about this and although I'm not much of help here, here's what I know on the subject:
  • To create a new boundary condition, check this page: http://openfoamwiki.net/index.php/Ho...dary_condition
  • Look into the source code of all of the other boundary conditions for clues on how to do this.
  • For simulating open areas, AFAIK there are a few standard boundary conditions already in OF:
    • Symmetry patch - probably not exactly what you're looking for, but it's possibly the closest you'll find in OF that will respect such a boundary condition.
    • Atmospheric patches: "atmBoundaryLayerInletEpsilon", "atmBoundaryLayerInletVelocity" and "pressureInletOutletVelocity". For more ideas, run:
      find $FOAM_TUTORIALS -name U | xargs grep -isl atm
      and check the tutorials listed by that command line.
Best regards,
Bruno
Old   December 26, 2012, 13:57
adambarfi's Avatar
Mostafa Mahmoudi
thank you Bruno,
I simplified my problem so that my problematic boundary has just one condition:
dv/dx=0
which the v is y-component of U.
any body knows how can I apply this condition?
Thanks
Channel flow- How to apply "Translational Periodicity" Giorgitseli CFX 3 May 30, 2011 06:17
How to apply KINETIC rate equation on walls SEEMI FLUENT 0 August 28, 2008 08:07
Relief Plots in CFX Michael CFX 15 June 30, 2006 08:01
Which B.C. i should apply for this problem?urgent raivish FLUENT 0 January 6, 2006 08:48
Is it possible apply AC and DC at the same time andyslee Main CFD Forum 0 January 28, 2003 23:39
