sprayEngineFoam - floating point exception error |
December 16, 2012, 13:36 |
ri
I am attempting to run a simulation using sprayEngineFoam using the standard kiva geometry provided with enginefoam . I have used the system folder and engine geometry files of enginefoam and the spraycloudproperties/chemistry/thermophysical/combustion files of sprayfoam. The simulation runs until the point of injection, where after the 1st injection of particles, I recieve the following floating point exception error: Solving cloud sprayCloud #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 Foam::C7H16:(double, double, double) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libliquidProperties.so" #4 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #5 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #6 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #7 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #8 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #9 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #10 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #11 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #12 in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/sprayEngineFoam" #13 __libc_start_main in "/lib64/libc.so.6" #14 at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception I have attached my case folder (The geometry is the otape17 kiva file not included in the zip), Please could someone have a look at this and see where I could be going wrong. Many thanks, ris. |
December 17, 2012, 16:07 |
ri
I managed to overcome the problem. I defined flowrateprofile in seconds rather than CAD which was a silly misatke. Also I increased the number of ncorrectors and switched off momentum predictor.
December 17, 2012, 16:46 |
Marco A. Turcios
Rep Power: 28 |
The latest version of sprayEngineFoam has injection defined in terms of CA. But I'm glad you fixed your problems.
May 27, 2013, 07:01 |
sprayEngineFoam
Vijay Bhaskar Devarapalli
Rep Power: 12 |
Hello Sir,
I am new to OpenFoam and i am looking at simulating sprayEngineFoam .unfortunately in my version of OF i dont have any tutorial . Nevertheless I have combined engineFoam and sprayFoam but still couldnot take it ahead. Any help from people who has done sprayEngineFoam will b ehighly appreciated ! Thanks , Vijay. |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
