PISO in FLUENT vs. OpenFOAM
Like Tree1Likes
  • 1 Post By Industrial_CFD
Old   February 4, 2013, 20:40
Default PISO in FLUENT vs. OpenFOAM
Anonymous
Industrial_CFD is on a distinguished road
Hi guys,
I am trying to get an LES case set up in openfoam, and I have been trouble shooting with FLUENT. FLUENT iterates PISO until the specified max iterations are reached ( or until convergence). Is there anyway to run pisoFOAM like this? Would this implementation be pimpleFoam?
Cheers
Ahmed Gohar likes this.
Industrial_CFD is offline   Reply With Quote
Old   February 5, 2013, 09:43
Christian Lucas
Chris Lucas is on a distinguished road
have a look at pimpleFoam. However, as I know, pimpleFoam doesn't check if the solution is converged. You have to programm it (a guess 10 lines of code) yourself.
Kind Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   February 7, 2013, 10:14
Default Update
Anonymous
What is really amazing is that OpenFOAM won't converge compared to the same settings in FLUENT (I think anyway). FLUENT handles the case easily, whereas OpenFOAM cannot converge the pressure term.
It is really strange. I'm starting to wonder if it is a bug or something.
Old   February 11, 2013, 05:43
Christian Lucas
the reason for the different results is not a bug. Some of the internal program structure is different.
Fluent has probably internal limiter that help to converge the solution (using numerical diffusion) and openfoam doesn't.
What are you trying to simulate. What schemes do you use. What OF version? Is time accuracy important?
Kind Regards,
Christian
[Other] OpenFoam Mesh to Fluent Mesh, 2D lordvon ANSYS Meshing & Geometry 1 January 14, 2022 12:20
[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam matteo_gautero OpenFOAM Meshing & Mesh Conversion 11 July 14, 2020 12:09
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Fluent elbow in Openfoam chemeng OpenFOAM 1 January 21, 2010 03:52
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
