Spalart Allmaras DDES - circular cylinder
Old   February 24, 2013, 08:43
Default Spalart Allmaras DDES - circular cylinder
edoardo
albertofast is on a distinguished road
Dear OpenFOAM users,
I want to make some aeroacoustical simulations coupling OpenFOAM with an opensource acoustic simulation code.
I am trying to simulate the von-karman vortex street after a circular cylinder at Re=166000. After performing 2D incompressible simulation with pimpleFoam solver and a k-omega SST turbulence model (getting quite good results in term of force Coefficients and Strouhal number), I would like to improve my simulation using the Spalart Allmaras DDES hybrid turbulence model. I made few tests (2D case), but I'm getting a non-physical behaviour (look at the animation). I also attached the case-study folder.
I would be very pleased to you if you could get me some suggestions.
Thank you very much!
1)DDES case-study: https://mega.co.nz/#!osgCHZYB!Vf4Yxg...TxQfzgX-sgWeGw
2)DDES animation (U magnitude):
https://mega.co.nz/#!JlxVQCCI!E0xGLS...cUx-AD5TmCu-1o
3) komegaSST case-study:
https://mega.co.nz/#!JgYDwSob!T9EYAl...5bG53ncqcMSWcA
4)komegaSST animation:
https://mega.co.nz/#!dkZmmIwB!KVs80U...TtuPfh6eXrYZnQ
PS: Sorry , I moved this thread which was previously posted in the wrong section, thanks!
albertofast is offline   Reply With Quote
Old   April 9, 2013, 08:19
kkpal is on a distinguished road
the website you posted does not work. Your cases can not be downloaded!
kkpal is offline   Reply With Quote
Old   April 9, 2013, 09:25
edoardo
Hello!
I've just checked the links and they work! Can you please specify what kind of problem the browser gives you?
Thanks!
Old   April 9, 2013, 09:38
Ilya
skeptik is on a distinguished road
For my browser it needs to set up Flash.
But i have one question about your case. Did you use empty BC with one cell thick domain both in SST and DES case?
practice makes perfect
skeptik is offline   Reply With Quote
Old   April 10, 2013, 09:40
fsaltara is on a distinguished road
I think that you can't use DDES in a 2D simulation. DDES is a hybrid RANS-LES method in which you should capture the large 3D eddies in the wake. In a 2D simulation you are going to miss the effect of the vortex stretching that is important in the energy cascade process.
Probably this is the explanation for the non-physical results that you got.
fsaltara is offline   Reply With Quote
Old   August 1, 2015, 22:53
J.-H. Wang
f0208secretx is on a distinguished road
Originally Posted by albertofast View Post
Hello!
Thanks!
Its always great when someone shares a case file to help us novice..
I was wondering if you have made the SA-DDES model work and for more complicated geometries? If yes, would you mind sharing your discovery? Thanks!
f0208secretx is offline   Reply With Quote
Old   August 5, 2015, 10:33
er_trebbia is on a distinguished road
Hi f0208secretx
Basically, I have to perform a S-A DDES, and I am trying to modify the channel395 tutorial case for the beginning, then I will go to a (very) more complex geometry.
I would suggest you to do the same. I will post a tutorial as soon as possible.
er_trebbia is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
