Error on hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>
Old   February 25, 2013, 07:08
Default Error on hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>
Joshua
yhlee is on a distinguished road
I faced error messages below when I was to solve a simple case with chtMultiRegionSimpleFoam.
Please help me - where do I start to find the reason for this error message?
*** Reading fluid mesh thermophysical properties for region hecavity
Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hRhoThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hRhoThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hRhoThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicRhoThermo::addfvMeshConstructorToTable< Foam::hRhoThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicRhoThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/home/joshua/OpenFOAM/joshua-2.1.1/platforms/linux64GccDPOpt/bin/chtMultiRegionHeatgenerationSimpleFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
yhlee is offline   Reply With Quote
Old   February 25, 2013, 18:05
Retired Super Moderator
Bruno Santos
Greetings Joshua and welcome to the forum!
Not much information you're giving us. All that can be seen from this is that:
This implies that something is improperly defined, such as temperature set at 0 Kelvin, or pressure defined at 0 Pa... or something else.
Best regards,
Bruno
Old   February 25, 2013, 21:11
Joshua
It was a problem of unrealistic boundary condition generated in the 0 directory.
Actually a zero kelvin problem.
Thank you for your great answer Bruno.
