moving mesh problem, simulating a floating plate |
February 28, 2013, 08:10 |
Hi everybody,
I want to model a floating plate at the surface of a fluid. the geometry is a rectangular that its west boundary condition is U=cte. I have some questions: 1.Should I use of the interDyMFoam, floatingObject tutorial? 2.If yes, how should I modify the dynamicMeshDict to achieve my purpose? 3.Is it necessary that my model has an atmosphere above it or not? any hint will be appreciated thanks a lot, Mostafa |
March 2, 2013, 10:06 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Mostafa,
It really depends on what you're trying to simulate! From your description, I can't figure out why and how the plate is over the surface in the first place... in fact, my first impulse was to say that the very first tutorial of the OpenFOAM User Guide was good enough So the questions back to you are:
Bruno
March 4, 2013, 11:21 |
Dear Bruno,
If I want to speak in details, I want simulate a floating rectangular over a fluid. in the fluid I have natural convection and the purpose is the velocity of floating object in my geometry. the object is floating in a way that we can assume it hasn't any vertical motion. the object has a limited length, about a quarter of surface length. I think the moving cone tutorial has some similarity with my model. with this difference that the object in this example has a velocity. in other word I first want to simulate a geometry that has an inlet velocity and then I'll combine the buoyantBoussinesqSimpleFoam whit a solver that it can simulate my problem. thank you Mostafa |
March 4, 2013, 17:31 |
Bruno Santos
Rep Power: 128 |
Hi Mostafa,
I honestly don't know what to suggest to you. But what I do know is that:
Best regards, Bruno
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
Moving Mesh Velocity Issue: Mesh velocity does not equal displacement | Doginal | CFX | 2 | September 8, 2011 12:02 |
moving Mesh problem | ulisses | OpenFOAM | 1 | September 3, 2010 19:30 |
Moving (structured) mesh | Jesper | CFX | 5 | February 2, 2007 03:43 |
