tableProperties.lookup(Y[i].name()) problem when run my case
Old   December 12, 2013, 03:30
Default tableProperties.lookup(Y[i].name()) problem when run my case
赵庆良
zqlhzx is on a distinguished road
Hi foamer,
The following is my codes in my readTableProperties.H and it can be compiled successfully with my solver.
Info<< "Reading table properties\n" << endl;
    IOdictionary tableProperties
        IOobject
            "tableProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
FieldField<Field,scalar> tspecies(19);
    for (label i=0; i<Y.size(); i++)
                  scalarField A(tableProperties.lookup("Y[i].name()"));
                  tspecies[i]=A;
What I'd like to ask is something about "(tableProperties.lookup("Y[i].name()")".In my tableProperties ,it is :
FoamFile
version     2.0;
format      binary;
class       dictionary;
location    "constant";
object      tableProperties;
CH4
0.0000    0.0120    0.0240    0.0360    0.0480    0.0060    0.0720    0.0840    0.0960    0.1080
0.1200    0.1320    0.1440    0.1560    0.1680    0.1800    0.1920    0.2040    0.2160    0.2280
0.2400    0.2520    0.2640    0.2760    0.2880    0.3000    0.3120    0.3240    0.3360    0.3480
0.3600    0.3720    0.3840    0.3960    0.4080    0.4200    0.4320    0.4440    0.4560    0.4680
0.4800    0.5000    0.5250    0.5500    0.5750    0.6000    0.6250    0.6500    0.6750    0.7000
0.7250    0.7500    0.7750    0.8000    0.8500    0.9000    0.9500    1.0001
O2
CO2
H2O
(In fact,the values in different species is different.I just show it as example).It should be that Y[0].name()=CH4,Y[1].name()=O2.Y[2].name()=CO2,Y[3].name()=H2O. I want to make "scalarField A" is equal to the values for different species.
So lookup (Y[i].name).
If I use
scalarField A(tableProperties.lookup("CH4"))
it can work,and my case can run.However,if I use
then I run my case ,it give me error:
keyword Y[i].name() is undefined in dictionary "/home/acer/OpenFOAM/acer-2.2.2/run/singlefirepoolx/constant/tableProperties"
Then I get rid of the "" like:
scalarField A(tableProperties.lookup(Y[i].name()))
it still gave me error:
FOAM FATAL ERROR:
hanging pointer at index 0 (size 19), cannot dereference
From function PtrList:perator[]
in file /opt/openfoam222/src/OpenFOAM/lnInclude/PtrListI.H at line 150.
FOAM aborting
How can I modify my codes above to make case run ?Could you give me some advises?Thank you !
zqlhzx is offline   Reply With Quote
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
Big Difference Between Serial run and Parallel run case alundilong OpenFOAM Programming & Development 1 March 20, 2013 15:52
[blockMesh] Problem with 0012 simple case Tetragramm OpenFOAM Meshing & Mesh Conversion 3 June 20, 2012 03:44
problem when I run the case Rui Siemens 1 February 1, 2007 06:25
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
