blood flow - aneurysm
Like Tree2Likes
  • 1 Post By JR22
  • 1 Post By GerhardHolzinger
Old   March 21, 2013, 02:57
Default blood flow - aneurysm
stephane sanchi
openfoam_user is on a distinguished road
Hi OF-users,
I'd like to model the blood flow in the aneurysm.
Blood characteristics are:
- density: 1080 kg/m3
- kinematic viscosity: 3.7037e-06 m2/s
Which solver do you recommend for such a computation ?
I want to start with a steady-state solver.
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   March 21, 2013, 03:23
akidess's Avatar
Anton Kidess
You specified the viscosity as a constant, thus you can use simpleFoam. In the future, you can easily find the answer to such a question here: http://www.openfoam.com/features/standard-solvers.php
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 21, 2013, 03:30
stephane sanchi
Hi Anton,
OK.
But with the simpleFoam solver you don't need the density. Does it mean that density is equal to 1 or not ?
You only set the kinematic viscosity.
Best regards,
Stephane.
Old   March 21, 2013, 03:43
akidess's Avatar
Anton Kidess
If the density is constant, the equations can be rewritten such as that you do not have to explicitly specify it. Implicitly it comes back in the use of kinematic instead of dynamic viscosity. You can find details in any fluid mechanics textbook.
Old   March 21, 2013, 05:24
stephane sanchi
Hi Anton,
Now it works. I put laminar as RASModel in the RASProperties file.
Previously I had kEpsilon as RASModel with turbulence off.
So it means that a laminar computation is not equal to a turbulent computation with turbulence off !!!
Best regards,
Stephane.
Old   March 21, 2013, 05:44
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Blood is non-newtonian also. Does it matter at this scale and conditions?
chaitanyaarige likes this.
JR22 is offline   Reply With Quote
Old   March 21, 2013, 06:06
stephane sanchi
I think you can assume blood as a Newtonian fluid in (large) arteries.
But in small capillaries it must be considered as non-Newtonian fluid.
Regards,
Stephane.
Old   March 21, 2013, 06:22
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Originally Posted by openfoam_user View Post
Hi Anton,
Best regards,
Stephane.
IF you look at the source code of simpleFoam, you will find, that simpleFoam always uses a RAS turbulence model.
This are some lines of simpleFoam.C
Application
    simpleFoam
Description
    Steady-state solver for incompressible, turbulent flow
#include "fvCFD.H"
#include "singlePhaseTransportModel.H"
#include "RASModel.H"
#include "simpleControl.H"
#include "IObasicSourceList.H"
You see, the header RASModel.H is included instead of turbulenceModel.H. E.g. compare the first lines of code of simpleFoam with the first lines of pimpleFoam.
The file createFields.H of simpleFoam contains the following lines:
singlePhaseTransportModel laminarTransport(U, phi);
    autoPtr<incompressible::RASModel> turbulence
        incompressible::RASModel::New(U, phi, laminarTransport)
A RAS turbulence model is create/ used in any case, so the switch turbulence of turbulenceProperties is inactive.
GerhardHolzinger is offline   Reply With Quote
Old   March 21, 2013, 06:55
stephane sanchi
Hi Gerhard,thanks for your useful information.
Best regards,
Stephane.
Pulsatile blood flow John H FLUENT 7 March 3, 2022 07:50
Modeling blood flow - FloWorks mcneelyd FloEFD, FloWorks & FloTHERM 2 June 15, 2009 12:53
FLUENT BLOOD FLOW RATE Christoforos FLUENT 0 September 18, 2008 10:08
3D pulsatile blood flow UDF Michal Main CFD Forum 0 February 25, 2005 07:18
Fluent blood flow BC Michal Main CFD Forum 3 February 17, 2005 03:17
