Turbulent flow over NACA0012 airfoil validation case (openfoam.com) |
January 18, 2020, 05:03 |
Luke
Hello everyone!
I’m trying to recreate a validation case of NACA0012 airfoil exactly how they did it on openfoam.com website: https://www.openfoam.com/documentati...irfoil-2d.html They claim that the base for this case is a tutorial case from /incompressible/simpleFoam/airFoil2D so that’s the first thing I copied. Then I had to download the 3D mesh: (3-D) 2 x 897 x 257 (2 x 513 point on airfoil surface) from this website: https://turbmodels.larc.nasa.gov/naca0012_grids.html Standard plot3dToFoam command didn't work, because it was producing an error: Code:
Create time Reading 1 blocks block 0 nx:2 ny:897 nz:257 Reading block points block 0: Reading 461058 x coordinates... Reading 461058 y coordinates... Reading 461058 z coordinates... Reading 461058 blanks... --> FOAM FATAL IO ERROR: Attempt to get back from bad stream file: n0012_897-257.p3dfmt at line 461062. From function bool Foam::Istream::getBack(Foam::token&) in file db/IOstreams/IOstreams/Istream.C at line 56. FOAM exiting Code:
plot3dToFoam -noBlank n0012_897-257.p3dfmt Code:
Create time Reading 1 blocks block 0 nx:2 ny:897 nz:257 Reading block points block 0: Reading 461058 x coordinates... Reading 461058 y coordinates... Reading 461058 z coordinates... Looking at cell 0 0 0 to determine orientation. Right-handed block. Merged points within 2.22045e-16 distance. Merged from 461058 down to 460672 points. Creating cells Creating boundary patches --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 460672 undefined faces in mesh; adding to default patch. Writing polyMesh End Code:
autoPatch -overwrite 15 Code:
Create time Create polyMesh for time = 0 Mesh read in = 0.91 s Feature:15 minCos :0.965926 Assigned 512 faces to patch auto0 Assigned 229376 faces to patch auto1 Assigned 229376 faces to patch auto2 Assigned 512 faces to patch auto3 Assigned 896 faces to patch auto4 End Code:
decomposePar simpleFoam Code:
Time = 471 smoothSolver: Solving for Ux, Initial residual = 0.403553, Final residual = 0.00133943, No Iterations 52 smoothSolver: Solving for Uz, Initial residual = 0.423146, Final residual = 0.00205817, No Iterations 40 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib64/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) EDIT: Nvm, I figured it out. Turned out I messed up my BC . Last edited by Luke_M; January 21, 2020 at 11:55. |
July 5, 2021, 18:45 |
GS
Rep Power: 7 |
I am trying to run this same case. Can you explain how to edit the files created by autoPatch? I cannot find any useful documentation on how to use this utility.
Validation: Turbulent Channel Flow, pisoFoam, LES | Xiaoyu Yang | OpenFOAM Running, Solving & CFD | 23 | December 19, 2019 11:51 |
SA-DDES Validation laminar or turbulent flow? | Davide95 | OpenFOAM Running, Solving & CFD | 0 | November 23, 2018 14:50 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Turbulent Channel validation case - Pressure gradient | ZviH | Main CFD Forum | 2 | July 8, 2015 16:11 |
