Unhandled coupledPolyPatch type cyclic
Old   April 7, 2013, 12:01
Default Unhandled coupledPolyPatch type cyclic
Ariane
Ariane is on a distinguished road
I am working on simulating the flow over a 3D two-element infinite wing with a flap, in order to reduce the noise at the flap leading edge.
I am using snappyHexMesh, OpenFOAM with the LES turbulence model SpalartAllmarasDDES, and cyclic boundary conditions for the surfaces parallel to the flow.
When I run a simulation, I get a fatal error, Unhandled coupledPolyPatch type cyclic, after the first iteration which is writen into a file.
I have copied the error message below, which indicates it is linked to isoSurface. I also read this problem can sometimes be fixed by changing isoSurface to isoSurfaceCell in the controlDict file. However, I have no isoSurface function in my controlDict file, and I am confused as to how to implement it.
When running snappyHexMesh, I get a foam warning at the Morphing iteration 0 concerning excessive displacement, which increases te size of the domain by 10^-18 m on one of the surfaces with a cyclic boundary. Perhaps these errors are related ?
I also get a negative, very small lift coefficient of about 10^-8, which is of the order of 10^-4 when I use zeroGradient ontead of cyclic boundary conditions.
I have attached the snappyHexMesh and controlDict files I am using.
Any help would be greatly appreciated, especially as I am running on a tight schedule.
Thank you !
--> FOAM FATAL ERROR:
From function isoSurface::collocatedFaces(const coupledPolyPatch&) const
in file sampledSurface/isoSurface/isoSurface.C at line 94.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::isoSurface::collocatedFaces(Foam::coupledPol yPatch const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#3 Foam::isoSurface::isoSurface(Foam::GeometricField< double, Foam::fvPatchField, Foam::volMesh> const&, Foam::Field<double> const&, double, bool, double) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#4 Foam::sampledCuttingPlane::createGeometry() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#5 Foam::sampledCuttingPlane::update() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#6 Foam::sampledSurfaces::update() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#7 Foam::sampledSurfaces::write() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#8 Foam::OutputFilterFunctionObject<Foam::sampledSurf aces>::execute(bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so"
#9 Foam::functionObjectList::execute(bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#10 Foam::Time::run() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#11
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
Abandon (core dumped)
Last edited by Ariane; April 7, 2013 at 12:05. Reason: Forgot to mention something
Ariane is offline   Reply With Quote
Old   April 8, 2013, 04:53
Ariane
It turns out the Unhandled coupledPolyPatch type cyclic error arrose from the fact I had included a cutingPlane function in controlDict.
However, I haven't figured out how to get rid of the foam warning about excessive displacement which arises at the Morphing iteration 0 of snappyHexMesh. It slightly changes the domain, which must be a reason why my results are wrong.
Old   April 20, 2016, 10:52
Hang Meng
windsimu is on a distinguished road
Send a message via Skype™ to windsimu
Hi, I also faced the same problem. Have you solved it now?
windsimu is offline   Reply With Quote
unhandled coupledpolypatc
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 17:18
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
