Wrong results from motorByke tutorial in OpenFoam 2.1.1 |
April 15, 2013, 08:07 |
José Sánchez
Rep Power: 13 |
Dear all,
The results I get after running the motorBike tutorial are wrong, but I am not getting any error message during execution. Apart from the resulting data everything seems to work properly. The mesh seems to be correct and I have checked the tutorial files. I have executed other tutorials obtaining the expected results (for simpleFoam and other solvers for incompressible fluid). Simply I just do not know why only the motorByke tutorial give wrong results and so I cannot rely on any data I could obtain from any execution. The only thing I came up with is that I do not have administrator privileges on the computers where I am working with OpenFoam-2.1.1 (which Ubuntu version is 11.04). The installation directory is "/opt" while in the installation guide it is recommended "/home/OpenFOAM" for user without administrator privileges, but I do not know if this really matters because other tutorials give the expected results. Any suggestion, solution or explanation will be very appreciated. Thank you, José Sánchez. Post-procesing images of wrong data: Pressure: https://docs.google.com/file/d/0Byfa...it?usp=sharing https://docs.google.com/file/d/0Byfa...it?usp=sharing Velocity: https://docs.google.com/file/d/0Byfa...it?usp=sharing https://docs.google.com/file/d/0Byfa...it?usp=sharing Last edited by jsc; April 15, 2013 at 08:24. Reason: Add post-processing images |
April 15, 2013, 14:04 |
Jose Rey
Rep Power: 17 |
Can you confirm that simpleFoam ran, or only potentialFoam (look in the logs). Also, I can see in paraview that you have on the top Time = 0, try using the forward button to the last time step (which should be for simpleFoam). I ran the tutorial using ./Allrun, and got 5 time steps (showed the last one using ). The last one has the velocity profile fully developed (Time=500, #5).
April 15, 2013, 17:13 |
José Sánchez
Rep Power: 13 |
Now I can see the correct results.
Thank you for the advice. I already know that there were 6 time steps but for some reason I was obcecated in that the one displayed was the last one. But as you have shown it was not. Thank you for your soon answer, I was getting mad checking every file and .log. As you would have notice I am new into OpenFOAM and Paraview. Thank you very much, José Sánchez. Last edited by jsc; April 15, 2013 at 17:16. Reason: Solved |
April 16, 2013, 07:26 |
José Sánchez
Rep Power: 13 |
The issue is solved, but I do not know why. Because I have found other images from paraview with wrong data and time step 5. Anyway, thank you JR22 for your help.
If someone it is interested next I explain the complet case. When I first installed openfoam I had problems with paraview. Navigating through this forum I found a solution from wyldcat (close to the end of the next thread): http://www.cfd-online.com/Forums/ope...se-11-4-a.html Running "parafoam" with the option "builtin" solved the problem. Then the problem of the wrong results appeared. Yesterday, after reading the reply from JR22 I run "parafoam". For some reason (probably exhaustion) I forgot the "-builtin" option. ˇit worked anyway! (it was not suppose to). But I did not realize that I have not used the "-builtin" option so ,as the data displayed was correct, I though that for some reason I have forgotten to change the time steps in paraview all the time (when in reality I have not forgotten). So now the situation is as follows. -Although at first "parafoam" only worked with the "-builtin" option and the modification from wyldcat, now works without it. I have checked the paraFoam file and the modification sugested by wyldcat is gone (I do not remember changing this file ), Everything I changed seems to be exactly as it was when parafoam did not work. So I do not understand why at first parafoam did not work and now it does (because the only file I change, now it is exactly like it was at first). -Now with the option "-builtin" I get in paraview the wrong data. Also the GUI that appears when I run the "-builtin" option has slightly changed. (I guess all of this is normal since the change from wyldcat to make it works has been removed). So now I do not have any problem (openfoam works and also paraview ) but I do not now why. Maybe running "paraFoam -builtin" has created any register which solved the issue? Last edited by jsc; April 16, 2013 at 07:30. Reason: ortography |
motorbike, openfoam 2.1.1, wrong pressure, wrong velocity |
[OpenFOAM.org] OpenFOAM 2.1.1 installation on openSUSE 12.2 32 bit | saturn_53 | OpenFOAM Installation | 13 | February 1, 2015 04:17 |
OpenFOAM 2.1.1 Installation Errors on RHEL 6.3 | tgvosk | OpenFOAM Installation | 15 | July 5, 2012 18:43 |
download openfoam tutorial | azoweil | OpenFOAM | 3 | March 5, 2012 15:14 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
