how to plot Cp for unsteady flow past a cylinder
Like Tree2Likes
  • 2 Post By fredo490
Old   April 16, 2013, 20:41
Default how to plot Cp for unsteady flow past a cylinder
Derek2580
rogerliu is on a distinguished road
how to plot Cp for unsteady flow past a cylinder?
I use pimpleFoam to calculate Cd and Cl.
but how to calculate Cp? and finally plot it vs. X Position
Thanks!
rogerliu is offline   Reply With Quote
Old   April 16, 2013, 22:49
HECKMANN Frédéric
fredo490 is on a distinguished road
You can use Paraview to plot this. Just open your case, then use the calculator to compute the Cp by your own. Just apply the formula drom Cp.
The calculator looks like this:
fredo490 is offline   Reply With Quote
Old   April 16, 2013, 23:20
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
What expression for example is suitable for total pressure?
immortality is offline   Reply With Quote
Old   April 17, 2013, 00:04
Default one more question
Derek2580
but the Cp I want to plot (vs. X position) is just around the object (e.g. cylinder), how can I capture the pressure value on the cylinder surface??
Thanks!
Old   April 17, 2013, 00:09
HECKMANN Frédéric
1) open your case with the wall only (or any patch)
2) use the calculator to get Cp
Cp = (P - P_inf) / (1/2 * rho_inf * V_inf ^ 2)
If you have a decomposed part, you need to select the step 1 (and not 0) to do the calculation. It seems that there is a bug if you use the first step.
3) use the filters -> plot on intersection curve to get the curve.
You can also use the sampling function from openfoam but I never use it so I don't have any example. http://www.openfoam.com/features/run...processing.php
immortality and Gang Wang like this.
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 21:19
Flow past 2 smooth circular cylinder slip FLUENT 0 July 8, 2010 18:45
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 06:17
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
