Temperature increases suddenly
Old   November 28, 2015, 09:22
Thumbs up Temperature increases suddenly
Mr.liu
lx882211 is on a distinguished road
Hi
I am a new foamer, and these days i am studying reactingFoam.
I turn off the chemistry and combustion in these two properties, run a cold case (swirl combustion), just one inlet, coflow and outlet. I meet the problem like this:
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG: Solving for O2, Initial residual = 0.830952, Final residual = 2.2885e-07, No Iterations 32
DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for CH4, Initial residual = 1.05216e-80, Final residual = 1.05216e-80, No Iterations 0
DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 0.870332, Final residual = 5.56243e-07, No Iterations 31
min/max(T) = 200, 5000
DICPCG: Solving for p, Initial residual = 0.0160394, Final residual = 6.018e-19, No Iterations 1
time step continuity errors : sum local = 1.34074e-06, global = -1.56373e-07, cumulative = -0.000144214
DICPCG: Solving for p, Initial residual = 2.51355e-07, Final residual = 2.51355e-07, No Iterations 0
time step continuity errors : sum local = 1.42259e-06, global = -1.56104e-07, cumulative = -0.00014437
DILUPBiCG: Solving for epsilon, Initial residual = 0.997237, Final residual = 6.1094, No Iterations 1001
bounding epsilon, min: -2.11486e+71 max: 2.69686e+71 average: -5.5868e+65
DILUPBiCG: Solving for k, Initial residual = 0.868327, Final residual = 9.14489e-07, No Iterations 28
bounding k, min: -7.22251e+44 max: 3.27511e+44 average: -2.04433e+40
ExecutionTime = 9902.84 s ClockTime = 12857 s
Can anyone help me? i do not know whether it is the problems of my set boundary or Mesh?
lx882211 is offline   Reply With Quote
Old   June 8, 2017, 05:13
Post
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello Mr. Liu,
I believe this issue corresponds to an already reported issue in post: having trouble using reactingFoam with reactions turned off
If you don't think this is this same issue please attach your case or more general information regarding flow (such as laminar or turbulent?), courant number and such.
Swagga5aur is offline   Reply With Quote
reactingfoam, swirl combustion
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 11:43
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 04:56
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
where is the calculation of the temperature field Tobi OpenFOAM 1 July 30, 2012 10:40
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
