Surface normal velocity BC with zero gradient tangential, cylinder
Prev Previous Post   Next Post Next
Old   May 25, 2013, 07:22
Default Surface normal velocity BC with zero gradient tangential, cylinder
Cameron
c_dowd is on a distinguished road
Hi all.
I have a cylindrical flow in which I am specifying the velocity at the cylinder surface (flowing inwards) and having the top of the cylinder as a fixed pressure outlet. I would like
to create a boundary condition where only the surface normal velocity (ie; radial component) is specified, and there is a zero gradient condition in the tangential directions.
Currently I'm using the cylindricalvelocityinlet condition from the following thread:
http://www.cfd-online.com/Forums/ope...-openfoam.html
which works perfectly except for the shear it applies to the flow as it moves tangentially against the boundary. Basically I want a flow where no vorticity is generated (except along the bottom boundary), which is not what I am currently getting. Below I've attached a plot of the vorticity in the out of page direction, showing the effect of the shear on the flow.
I don't have a good enough understanding of the BC codes to create my own, and I'm not sure how I would create such a condition in groovyBC. Any help?
c_dowd is offline   Reply With Quote
cylinder, cylindrical, surface normal, velocity bc
Surface tangential gradient nzy102 OpenFOAM Post-Processing 2 December 5, 2018 09:50
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Surface normal gradient on unstructured mesh fumiya OpenFOAM 1 September 30, 2011 04:34
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
velocity normal to the surface srinivas Siemens 1 May 30, 2007 02:03
