can't read the librairy of a modified inlet condition |
June 10, 2013, 07:35 |
Eloïse
I am trying to run a simpleFoam simulation with a modified inlet condition, but it seems I can't read the library in which the inlet condition is defined. I get the following error message Code:
--> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96 could not load "VelRH.so" Code:
--> FOAM FATAL IO ERROR: Unknown patchField type VelRH for patch type patch I run with OpenFOAM 2.0.x. I created a velRH directory which contains the files functionVelRHFvPatchVectorField.C, functionVelRHFvPatchVectorField.H, and the Make directory which contains the files files and options (respectively below). Code:
functionVelRHFvPatchVectorField.C LIB = $(FOAM_USER_LIBBIN)/velRH Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = Code:
wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file functionVelRHFvPatchVectorField.C SOURCE=functionVelRHFvPatchVectorField.C ; g++44 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/share/apps/OpenFOAM-2.0.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/share/apps/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude -I/share/apps/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/functionVelRHFvPatchVectorField.o '.../eloisec-2.0.x/platforms/linux64GccDPOpt/lib/velRH.so' is up to date. Thanks for reading this long message Eloïse |
June 10, 2013, 07:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Eloïse,
Try the following command, to check if the library path is within visible reach: Code:
echo $LD_LIBRARY_PATH | grep "eloisec-2.0.x/platforms/linux64GccDPOpt/lib" And I'm assuming that you edited out what was at the "..." in ".../eloisec-2.0.x", because otherwise, that would be a real problem, since it's not a standard path Best regards, Bruno
June 10, 2013, 08:22 |
Eloïse
Hello Bruno,
Thanks for your fast answer 1) The path is present in the $LD_LIBRARY_PATH 2) The file velRH.so actually exist, and it is located in the proper directory Do you have any other idea? And you are right, I "shortened" the path the the library directory Regards, Eloïse |
June 10, 2013, 08:46 |
Bruno Santos
Rep Power: 128 |
Hi Eloïse,
Then the problem must be in the code itself. Without looking at it, it could any number of possibilities. The only other possibility that comes to mind is the name of the library, because the traditional naming (at least from what I've seen on Linux) is to prepend "lib" to the name: Code:
LIB = $(FOAM_USER_LIBBIN)/libvelRH Bruno
June 10, 2013, 09:59 |
Eloïse
Problem solved!
I shouldn't have looked that far... I just called VelRH.so instead of velRH.so in the controlDict. So classic Thanks for the help anyway! Regards, Eloïse |
Pressure boundary condition for unsteady velocity inlet | DanM | OpenFOAM Running, Solving & CFD | 6 | July 5, 2015 09:21 |
unsteady ramp inlet condition | pepe.aero | OpenFOAM Running, Solving & CFD | 10 | October 22, 2013 04:23 |
mass flow inlet condition is not properly specified in circulating fluidized bed | abinashlipun | FLUENT | 0 | April 19, 2013 02:28 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
Pressure Inlet Boundary Condition | Trinity_psu | FLUENT | 0 | June 1, 2005 14:15 |
