can not run simple foam..
Old   July 10, 2013, 12:11
Default can not run simple foam..
izna O'connor
izna is on a distinguished road
hello everyone..
i can not run simpleFoam at all..
i get this error all the time..ie with every tutorial i use..what can be the problem?
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/izna/Desktop/Askervein/6/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
izna is offline   Reply With Quote
Old   July 10, 2013, 15:44
reza sadeghi
reza1111 is on a distinguished road
Hi
Have you ever checked the instructions of openfoam installation?
can you run the cavity case after installation. please explain more details.
reza1111 is offline   Reply With Quote
Old   July 10, 2013, 15:48
izna O'connor
yes i can run with every other ie icofoam, pisofoam.. only simple foam not run....
Old   July 10, 2013, 16:00
reza sadeghi
I see you are working on your own case.
what error do you get by running one case of OF tutorial for example airfoil2D case?
Old   July 10, 2013, 16:03
izna O'connor
same one..all the time..
Old   July 10, 2013, 17:06
reza sadeghi
Hmmm!! go to the airfoil2D directory. and run the case by typing "./Allrun" in terminal.
Do you get the error?
Old   July 11, 2013, 04:52
izna O'connor
hi
when i run with airfoil2D is work perfetctly provided i did an allrun first..
now lets come back to another file of mine which i run
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 402.
also i was try to run a template online and when i did the allrun its said i have not enough permission..!!
bash: ./Allrun: Permission denied
now lets take the turbineSiting file..
its works well withthe ALlrun, the blokmesh and snappyhext mesh was fine.. when i run simplefoam..
see what happens..;
Create time
Create mesh for time = 254
Reading field p
cannot find file
file: /home/izna/Desktop/turbineSiting/254/p at line 0.
FOAM exiting
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Total pressure BC with simple foam duri OpenFOAM Running, Solving & CFD 1 March 20, 2012 08:05
what turbulent boundary conditions are needed for simple foam? sachinlb OpenFOAM Running, Solving & CFD 1 January 11, 2012 05:07
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
