August 2, 2013, 11:20 |
Open channel flow with interFoam
Maxim Sorockin
Rep Power: 13 |
Dear Foamers, I need some help.
I try to simulate flow in open channel with interFoam. I use setting from wigleyHull tutorial. I only changed the geometry of channel and inlet velocity (0.25 m/s). But I see instability in simulated results. Tel me please what need to change to get flow without instabilities. Screenshots of alpha, U and case setup are attached. Thanks a lot! Maxim |
August 3, 2013, 11:36 |
New settings
Maxim Sorockin
Rep Power: 13 |
I have moved form LTSInterFoam to interFoam and changed turbulence values setting. I think that problem with stability was in time constraints or wrong turbulent settings.
Now I use interFoam with maxCo=0.5 and maxAlphaCo=0.5. I set internalField and inlet value for k from expression k=1.5*(U*I)^2. U=0.25, turbulence intensity I put 1%. So k=9.375e-6. For mega - from expression omega=Cm^(-0.25)*k^0.5/L, Cm=0.09, turbulence length I put 7% of channel depth. So omega=5.324e-3. I deleted nut file in 0/ folder to OpenFOAM calculate nut values. But I still have flow instability. Help me please I am new in OpenFOAM and don't know what needs to do! New case setting are attached. Maxim |
August 5, 2013, 08:35 |
laminar
Maxim Sorockin
Rep Power: 13 |
If I turn off turbulence and simulate laminar flow I still obtain instability. What is the cause? Solution scheme or boundary condition? But I took boundary conditions from wigleyHull tutorial. I am confused.
Maxim |
August 6, 2013, 08:34 |
David GISEN
Rep Power: 16 |
The second case doesn't look bad in my opinion. You set turbulence at the inlet, and you get turbulence.
In the third case the reason might be some BC. If you say instability one thinks of numerical instability. You can check it via the residuals. In the forum there is a script for gnuplot that processes the values given in your .log-file (if you write a .log-file). |
August 6, 2013, 09:41 |
Maxim Sorockin
Rep Power: 13 |
Thank you for reply David!
The second case doesn't look bad in my opinion. You set turbulence at the inlet, and you get turbulence. I used initial setting from "wigleyHull" tutorial. "wigleyHull" used turbulence model too but flow is much more uniform. I simulated this case with flow3D (k-epsilon turbulence model, the same mesh) and had uniform flow. In the third case the reason might be some BC. How nice it would be to know exactly what it is - BC or solution scheme. If you say instability one thinks of numerical instability. You can check it via the residuals. In the forum there is a script for gnuplot that processes the values given in your .log-file (if you write a .log-file). It is good idea, thank you! Maxim |
August 6, 2013, 10:30 |
laminar, changed setup
Maxim Sorockin
Rep Power: 13 |
I changed setup for laminar simulation. I moved from 3D to 2D (xz plane) and divided inlet plane. Onto inlet and wall.
So now I have channel 85x1x17 m with mesh 340x1x170. Water depth is 15m. With BCs: inlet U: fixedValue; value uniform (0.25 0 0); alpha1: fixedValue; value uniform 1; p_rgh: zeroGradient; inletWall U: symmetryPlane; alpha1: symmetryPlane; p_rgh: symmetryPlane; outlet U: zeroGradient; alpha1: zeroGradient; p_rgh: zeroGradient; atmosphere U: pressureInletOutletVelocity; phi phi; value uniform (0 0 0); alpha1: inletOutlet; inletValue uniform 0; value uniform 0; p_rgh: totalPressure; bottom U: symmetryPlane; alpha1: symmetryPlane; p_rgh: symmetryPlane; I still have "instability" at inlet. It may be connected with wrong inlet BC. I will be glad any advice. The case is attached. Maxim |
August 7, 2013, 11:24 |
Mesh, BC or schems
Maxim Sorockin
Rep Power: 13 |
I made another changes.
My mesh had dx/dz ratio 2.5. I made dx=dz to remove mesh as one of cause that may induce instability. Then I changed BCs, accordingly Matthew Denno http://www.cfd-online.com/Forums/ope...lowing-up.html inlet U: fixedValue; value uniform (0.25 0 0); alpha1: fixedValue; value uniform 1; p_rgh: buoyantPressure; value uniform 0; inletWall U: fixedValue; value uniform (0 0 0); alpha1: zeroGradient; p_rgh: buoyantPressure; value uniform 0; outlet U: inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); alpha1: inletOutlet; inletValue uniform 0; value uniform 0; p_rgh: inletOutlet; inletValue uniform 0; value uniform 0; atmosphere U: pressureInletOutletVelocity; value uniform (0 0 0); alpha1: inletOutlet; inletValue uniform 0; value uniform 0; p_rgh: totalPressure; bottom U: fixedValue; value uniform (0 0 0); alpha1: zeroGradient; p_rgh: buoyantPressure; value uniform 0; And I still have "instability" that arise at inlet and then result strongly nonuniform flow. I tried different "working" BC set from another threads but "instability" didn't disappeared. May be deal in solution schemes. Can anybody help me? Please! Maxim |
August 9, 2013, 10:14 |
fvSolution
Maxim Sorockin
Rep Power: 13 |
I took fvSolution setting from Matthew case and looks like "instability" disappeared.
Thank you Matthew for helpful post! Maxim |
October 20, 2013, 06:50 |
Mattew Case
#9 |
Hi Maxim
You refer to Matthew's case in the post above, can you provide a link to this. Thanks JFM |
channel flow, instability, interfoam |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
No fluid in open channel flow VOF | flow_CH | Fluent Multiphase | 2 | July 2, 2013 01:05 |
OpenFOAM open channel flow downsteam boundary condition | Brickman | OpenFOAM Running, Solving & CFD | 2 | November 5, 2012 20:14 |
Open Channel Flow | forsumit | FLUENT | 0 | October 1, 2009 02:01 |
