compressibleInterFoam diverges after restart
Old   August 8, 2013, 03:59
Default compressibleInterFoam diverges after restart
Stefan Hildenbrand
shildenbrand is on a distinguished road
Hi all,
I am running a compressibleInterFoam case starting from t=0 which seems to be running and converging nicely (see log_0.01.txt). In order to change the number of processors I stopped the simulation and made a restart. Unfortunately, after this restart I immediately get strange values of p_rgh and after a few more iterations the computation crashes (see log_cont_run.txt - I stopped before the crash occurs).
I also attached the logfile in the case I do not interrupt my computation (log_without_break.txt)
I am simulating the outflow of a liquid out of a car door sill. The viscosity of the liquid is temperature-dependant, therefore I modified compressibleInterFoam such that an additional (temperature-dependant) transport model is available.
I attached my 0.org directory - note that I use a time-dependant BC for Temperature, if I had not used it, my computation would have crashed immediately. Before I start the run I do a mapFields where I impose starting conditions for "alphawater" and "T".
My "main"-BCs are:
alphawater: constantAlphaContactAngle
p_rgh: fixedFluxPressure
p: calculated
T: uniformFixedValue
U: fixedValue
I can not post the geometry, however in case this helps, I attached a 2D-sketch of the door sill.
I hope I have supplied all necessary information to make my point - if you need more details, please tell me.
Does anyone have an idea where my mistake is?
Stefan
0.org.zip
log_0.01.txt
log_cont_run.txt
shildenbrand is offline   Reply With Quote
compressibleinterfoam, crash, p_rgh, restart
Can't restart 2-way FSI using ANSYS 14.0 Workbench MSHowes ANSYS 2 July 3, 2014 13:30
Problem at restart abonfi SU2 3 May 2, 2013 13:43
Problem with multiframe restart of two-way fsi coupled problem Dimone CFX 26 December 20, 2011 10:10
Restart for solidification atulverma FLOW-3D 2 May 15, 2009 06:25
v4 restart bug optima prime Siemens 3 February 2, 2009 22:51
