May 4, 2013, 23:09 |
dynamic Mesh is faster than MRF????
Dongyue Li
Rep Power: 17 |
Hi guys,
I am simulating a mixer3D case, totally mesh is about 200m. I expect MRFInterFoam could be faster than interDyMFoam, but via the log, interDyMFoam is faster. Both the result is fine.So why?any comments would be appreciated. MRFlog Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p_rgh Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 1, 1.00723, 1.00001 AMI: Patch target weights min/max/average = 1, 1.00723, 1.00001 Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 1 average: 1 bounding epsilon, min: 0 max: 20 average: 20 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading g Calculating field g.h No finite volume options present Creating MRF zone list from MRFProperties creating MRF zone: zone1 PIMPLE: Operating solver in PISO mode time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 1.07991e-05 Time = 1.07991e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0495223, No Iterations 19 time step continuity errors : sum local = 1.7138e-06, global = -1.29864e-08, cumulative = -1.29864e-08 DICPCG: Solving for p_rgh, Initial residual = 0.122609, Final residual = 0.00580765, No Iterations 14 time step continuity errors : sum local = 4.70704e-07, global = -4.78148e-09, cumulative = -1.77679e-08 DICPCG: Solving for p_rgh, Initial residual = 0.017567, Final residual = 9.90151e-08, No Iterations 161 time step continuity errors : sum local = 8.01748e-12, global = 5.02083e-14, cumulative = -1.77678e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.000142027, Final residual = 1.31604e-09, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.12205e-09, No Iterations 7 ExecutionTime = 9.97 s ClockTime = 10 s Courant Number mean: 0.00216553 max: 0.53051 Interface Courant Number mean: 0 max: 0 deltaT = 1.0177e-05 Time = 2.09761e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.44695e-30 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.160646, Final residual = 0.0072516, No Iterations 26 time step continuity errors : sum local = 5.00609e-07, global = 9.94811e-09, cumulative = -7.8197e-09 DICPCG: Solving for p_rgh, Initial residual = 0.0921909, Final residual = 0.00435461, No Iterations 8 time step continuity errors : sum local = 2.83072e-07, global = 2.82049e-09, cumulative = -4.99921e-09 DICPCG: Solving for p_rgh, Initial residual = 0.0085199, Final residual = 9.89058e-08, No Iterations 170 time step continuity errors : sum local = 6.29855e-12, global = -1.17153e-13, cumulative = -4.99932e-09 DILUPBiCG: Solving for epsilon, Initial residual = 3.50951e-05, Final residual = 2.19052e-09, No Iterations 2 bounding epsilon, min: -0.961442 max: 12468.1 average: 319.429 DILUPBiCG: Solving for k, Initial residual = 0.00849041, Final residual = 1.83622e-09, No Iterations 4 ExecutionTime = 18.62 s ClockTime = 18 s Courant Number mean: 0.00204717 max: 0.556823 Interface Courant Number mean: 0 max: 0 deltaT = 9.13693e-06 Time = 3.0113e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -7.2564e-31 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -7.53487e-31 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0608071, Final residual = 0.00295234, No Iterations 19 time step continuity errors : sum local = 2.65526e-07, global = -3.68452e-10, cumulative = -5.36777e-09 DICPCG: Solving for p_rgh, Initial residual = 0.0164258, Final residual = 0.000808253, No Iterations 13 time step continuity errors : sum local = 7.18554e-08, global = -1.17925e-09, cumulative = -6.54703e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00174533, Final residual = 9.50677e-08, No Iterations 153 time step continuity errors : sum local = 8.46815e-12, global = 6.33871e-14, cumulative = -6.54696e-09 DILUPBiCG: Solving for epsilon, Initial residual = 3.00088e-05, Final residual = 1.60449e-09, No Iterations 2 bounding epsilon, min: -3.14248 max: 11394.3 average: 319.679 DILUPBiCG: Solving for k, Initial residual = 0.00602194, Final residual = 8.43019e-10, No Iterations 4 ExecutionTime = 26.5 s ClockTime = 26 s Courant Number mean: 0.00183615 max: 0.525867 Interface Courant Number mean: 0 max: 0 deltaT = 8.68739e-06 Time = 3.88004e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.04223e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.04223e-30 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0338219, Final residual = 0.00151052, No Iterations 19 time step continuity errors : sum local = 1.2876e-07, global = 1.12176e-10, cumulative = -6.43479e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00809159, Final residual = 0.000383803, No Iterations 13 time step continuity errors : sum local = 3.19975e-08, global = 2.05515e-10, cumulative = -6.22927e-09 DICPCG: Solving for p_rgh, Initial residual = 0.000821271, Final residual = 9.88127e-08, No Iterations 147 time step continuity errors : sum local = 8.20908e-12, global = -2.54011e-14, cumulative = -6.2293e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.74772e-05, Final residual = 2.21332e-09, No Iterations 2 bounding epsilon, min: -15.8509 max: 10622.5 average: 320.093 DILUPBiCG: Solving for k, Initial residual = 0.0049088, Final residual = 8.57433e-10, No Iterations 4 ExecutionTime = 34.34 s ClockTime = 34 s Courant Number mean: 0.0017467 max: 0.513383 Interface Courant Number mean: 0 max: 0 deltaT = 8.46083e-06 Time = 4.72612e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.03781e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.6606e-30 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0229209, Final residual = 0.00111938, No Iterations 18 time step continuity errors : sum local = 8.28057e-08, global = 2.41502e-11, cumulative = -6.20515e-09 DICPCG: Solving for p_rgh, Initial residual = 0.0051387, Final residual = 0.000226864, No Iterations 14 time step continuity errors : sum local = 1.67717e-08, global = -6.4155e-12, cumulative = -6.21156e-09 DICPCG: Solving for p_rgh, Initial residual = 0.000532194, Final residual = 9.43961e-08, No Iterations 145 time step continuity errors : sum local = 6.98896e-12, global = 5.56208e-14, cumulative = -6.21151e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.59259e-05, Final residual = 4.43109e-09, No Iterations 3 bounding epsilon, min: -35.6881 max: 10019.6 average: 320.542 DILUPBiCG: Solving for k, Initial residual = 0.00429238, Final residual = 6.20346e-09, No Iterations 5 ExecutionTime = 43.51 s ClockTime = 43 s Courant Number mean: 0.00170077 max: 0.510754 Interface Courant Number mean: 0 max: 0 deltaT = 8.28266e-06 Time = 5.55439e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.68908e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -4.38537e-30 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0144755, Final residual = 0.000649306, No Iterations 18 time step continuity errors : sum local = 4.65693e-08, global = 2.10894e-11, cumulative = -6.19042e-09 DICPCG: Solving for p_rgh, Initial residual = 0.0030582, Final residual = 0.000147816, No Iterations 13 time step continuity errors : sum local = 1.05051e-08, global = 9.01834e-12, cumulative = -6.1814e-09 DICPCG: Solving for p_rgh, Initial residual = 0.000317831, Final residual = 9.03361e-08, No Iterations 140 time step continuity errors : sum local = 6.41349e-12, global = 1.32232e-13, cumulative = -6.18127e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.46021e-05, Final residual = 1.10753e-09, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.00385872, Final residual = 7.08998e-09, No Iterations 3 ExecutionTime = 52.81 s ClockTime = 52 s Courant Number mean: 0.00166523 max: 0.50848 Interface Courant Number mean: 0 max: 0 deltaT = 8.14356e-06 Time = 6.36875e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.73436e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.29233e-29 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0101018, Final residual = 0.000428819, No Iterations 18 time step continuity errors : sum local = 2.85356e-08, global = 2.1336e-12, cumulative = -6.17913e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00196009, Final residual = 9.6592e-05, No Iterations 13 time step continuity errors : sum local = 6.42842e-09, global = 8.08073e-12, cumulative = -6.17105e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00020677, Final residual = 9.61554e-08, No Iterations 138 time step continuity errors : sum local = 6.40504e-12, global = -1.40573e-13, cumulative = -6.17119e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.35861e-05, Final residual = 1.05688e-09, No Iterations 2 bounding epsilon, min: -1.13847 max: 9136.01 average: 321.43 DILUPBiCG: Solving for k, Initial residual = 0.00354651, Final residual = 5.20685e-09, No Iterations 3 ExecutionTime = 60.61 s ClockTime = 60 s Courant Number mean: 0.0016372 max: 0.506738 Interface Courant Number mean: 0 max: 0 deltaT = 8.0348e-06 Time = 7.17223e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.28447e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -7.93829e-30 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.00678436, Final residual = 0.000295459, No Iterations 17 time step continuity errors : sum local = 1.95926e-08, global = -6.30779e-12, cumulative = -6.1775e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00124079, Final residual = 6.04477e-05, No Iterations 14 time step continuity errors : sum local = 3.98948e-09, global = -3.47633e-12, cumulative = -6.18098e-09 DICPCG: Solving for p_rgh, Initial residual = 0.000133578, Final residual = 9.99504e-08, No Iterations 127 time step continuity errors : sum local = 6.59323e-12, global = -2.21552e-14, cumulative = -6.181e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.27288e-05, Final residual = 1.00723e-09, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.00330894, Final residual = 4.07864e-09, No Iterations 3 ExecutionTime = 68.02 s ClockTime = 68 s Courant Number mean: 0.00161543 max: 0.505443 Interface Courant Number mean: 0 max: 0 deltaT = 7.94783e-06 Time = 7.96701e-05 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.27255e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -4.56795e-29 Max(alpha1) = 1 Phase volume in zone innerCylinder = 73689.4 ml DICPCG: Solving for p_rgh, Initial residual = 0.0050451, Final residual = 0.000233662, No Iterations 16 time step continuity errors : sum local = 1.46823e-08, global = 4.15023e-12, cumulative = -6.17685e-09 DICPCG: Solving for p_rgh, Initial residual = 0.00085883, Final residual = 3.82176e-05, No Iterations 16 time step continuity errors : sum local = 2.40204e-09, global = 6.85582e-12, cumulative = -6.16999e-09 DICPCG: Solving for p_rgh, Initial residual = 9.63252e-05, Final residual = 9.71377e-08, No Iterations 126 time step continuity errors : sum local = 6.1099e-12, global = 9.08267e-14, cumulative = -6.1699e-09 DILUPBiCG: Solving for epsilon, Initial residual = 2.20023e-05, Final residual = 9.74754e-10, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.00312384, Final residual = 3.44313e-09, No Iterations 3 ExecutionTime = 75.58 s ClockTime = 75 s |
May 4, 2013, 23:12 |
Dongyue Li
Rep Power: 17 |
DyMlog
Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone innerCylinder Reading field p_rgh Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 1, 1.00723, 1.00001 AMI: Patch target weights min/max/average = 1, 1.00723, 1.00001 Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 1 average: 1 bounding epsilon, min: 0 max: 20 average: 20 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading g Calculating field g.h No finite volume options present PIMPLE: Operating solver in PISO mode time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 0 max: 0 deltaT = 1.07991e-05 Time = 1.07991e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 1.07991e-05 transformation: ((0 0 0) (1 (0 -0.000169632 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999981, 1.01009, 1.00001 AMI: Patch target weights min/max/average = 0.999872, 1.00789, 1.00001 Execution time for mesh.update() = 0.57 s time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 5.85724e-05, No Iterations 6 time step continuity errors : sum local = 1.1423e-15, global = -2.09364e-16, cumulative = -2.09364e-16 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0465405, No Iterations 2 time step continuity errors : sum local = 1.57011e-06, global = 1.87009e-08, cumulative = 1.87009e-08 GAMG: Solving for p_rgh, Initial residual = 0.0789648, Final residual = 0.00246715, No Iterations 2 time step continuity errors : sum local = 2.88529e-07, global = 6.79494e-10, cumulative = 1.93804e-08 GAMGPCG: Solving for p_rgh, Initial residual = 0.0106098, Final residual = 4.05951e-09, No Iterations 9 time step continuity errors : sum local = 4.86709e-13, global = 1.19577e-14, cumulative = 1.93804e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.000141365, Final residual = 9.72214e-07, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 9.04443e-07, No Iterations 4 ExecutionTime = 11.88 s ClockTime = 12 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.00219444 max: 0.530883 deltaT = 1.01693e-05 Time = 2.09684e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 2.09684e-05 transformation: ((0 0 0) (1 (0 -0.000329371 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999903, 1.0128, 1.00002 AMI: Patch target weights min/max/average = 0.999753, 1.00851, 1.00002 Execution time for mesh.update() = 0.73 s time step continuity errors : sum local = 4.58334e-13, global = 1.10632e-14, cumulative = 1.93804e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 1.85074e-05, No Iterations 6 time step continuity errors : sum local = 1.04091e-15, global = -3.97154e-17, cumulative = 1.93804e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.40366e-31 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.40366e-31 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.111485, Final residual = 0.00298827, No Iterations 4 time step continuity errors : sum local = 1.87951e-07, global = -8.61162e-10, cumulative = 1.85192e-08 GAMG: Solving for p_rgh, Initial residual = 0.0806247, Final residual = 0.0016671, No Iterations 2 time step continuity errors : sum local = 9.60968e-08, global = -1.21665e-09, cumulative = 1.73026e-08 GAMGPCG: Solving for p_rgh, Initial residual = 0.00729125, Final residual = 2.44918e-09, No Iterations 9 time step continuity errors : sum local = 1.22663e-13, global = 7.78887e-15, cumulative = 1.73026e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.26066e-05, Final residual = 6.98713e-08, No Iterations 1 bounding epsilon, min: -2.33489 max: 12270 average: 318.304 DILUPBiCG: Solving for k, Initial residual = 0.00893094, Final residual = 1.52782e-06, No Iterations 2 ExecutionTime = 22.12 s ClockTime = 22 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.00206649 max: 0.471772 deltaT = 1.07761e-05 Time = 3.17445e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 3.17445e-05 transformation: ((0 0 0) (1 (0 -0.000498641 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999807, 1.01565, 1.00003 AMI: Patch target weights min/max/average = 0.999626, 1.00917, 1.00003 Execution time for mesh.update() = 0.83 s time step continuity errors : sum local = 1.30033e-13, global = 8.21103e-15, cumulative = 1.73026e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 2.08231e-05, No Iterations 5 time step continuity errors : sum local = 1.14651e-15, global = 1.625e-16, cumulative = 1.73026e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.12177e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -4.14319e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.00275e-30 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.00924303, Final residual = 0.000183372, No Iterations 2 time step continuity errors : sum local = 2.01927e-08, global = -3.82154e-11, cumulative = 1.72644e-08 GAMG: Solving for p_rgh, Initial residual = 0.0010327, Final residual = 4.32465e-05, No Iterations 2 time step continuity errors : sum local = 4.73384e-09, global = -1.00248e-10, cumulative = 1.71641e-08 GAMGPCG: Solving for p_rgh, Initial residual = 0.000160943, Final residual = 6.14766e-09, No Iterations 6 time step continuity errors : sum local = 6.76895e-13, global = -2.3289e-14, cumulative = 1.71641e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.28376e-05, Final residual = 7.18948e-08, No Iterations 1 bounding epsilon, min: -25.3986 max: 11277.1 average: 318.745 DILUPBiCG: Solving for k, Initial residual = 0.00691905, Final residual = 1.49221e-06, No Iterations 2 ExecutionTime = 30.31 s ClockTime = 30 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.0021898 max: 0.476022 deltaT = 1.13173e-05 Time = 4.30618e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 4.30618e-05 transformation: ((0 0 0) (1 (0 -0.000676413 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999706, 1.01864, 1.00004 AMI: Patch target weights min/max/average = 0.999492, 1.00987, 1.00003 Execution time for mesh.update() = 0.77 s time step continuity errors : sum local = 7.10885e-13, global = -2.4288e-14, cumulative = 1.71641e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.44623e-05, No Iterations 5 time step continuity errors : sum local = 1.1549e-15, global = -7.19047e-17, cumulative = 1.71641e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -7.97699e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.53358e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.10898e-30 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.00313902, Final residual = 4.86501e-05, No Iterations 2 time step continuity errors : sum local = 6.11297e-09, global = 2.00984e-11, cumulative = 1.71842e-08 GAMG: Solving for p_rgh, Initial residual = 0.000415594, Final residual = 1.11061e-05, No Iterations 2 time step continuity errors : sum local = 1.39186e-09, global = 3.24225e-13, cumulative = 1.71845e-08 GAMGPCG: Solving for p_rgh, Initial residual = 5.9657e-05, Final residual = 7.36493e-09, No Iterations 5 time step continuity errors : sum local = 9.22573e-13, global = 5.22275e-14, cumulative = 1.71846e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.31122e-05, Final residual = 7.37862e-08, No Iterations 1 bounding epsilon, min: -17.1488 max: 10497.8 average: 319.131 DILUPBiCG: Solving for k, Initial residual = 0.00581176, Final residual = 1.37789e-06, No Iterations 2 ExecutionTime = 39.07 s ClockTime = 39 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.0022998 max: 0.481042 deltaT = 1.17617e-05 Time = 5.48235e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 5.48235e-05 transformation: ((0 0 0) (1 (0 -0.000861165 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999602, 1.02174, 1.00005 AMI: Patch target weights min/max/average = 0.999354, 1.0106, 1.00004 Execution time for mesh.update() = 0.81 s time step continuity errors : sum local = 9.58819e-13, global = 5.42002e-14, cumulative = 1.71846e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 1.96255e-05, No Iterations 6 time step continuity errors : sum local = 1.14831e-15, global = 7.02381e-17, cumulative = 1.71846e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -5.85705e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.53586e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.25193e-29 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.00171074, Final residual = 2.69953e-05, No Iterations 2 time step continuity errors : sum local = 3.65318e-09, global = -1.63339e-11, cumulative = 1.71683e-08 GAMG: Solving for p_rgh, Initial residual = 0.000266381, Final residual = 6.07096e-06, No Iterations 2 time step continuity errors : sum local = 8.20523e-10, global = 1.05994e-12, cumulative = 1.71693e-08 GAMGPCG: Solving for p_rgh, Initial residual = 3.85518e-05, Final residual = 3.00878e-09, No Iterations 5 time step continuity errors : sum local = 4.06444e-13, global = -2.41697e-14, cumulative = 1.71693e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.31698e-05, Final residual = 7.43642e-08, No Iterations 1 bounding epsilon, min: -14.0313 max: 9872.48 average: 319.451 DILUPBiCG: Solving for k, Initial residual = 0.00509662, Final residual = 1.40194e-06, No Iterations 2 ExecutionTime = 47.4 s ClockTime = 47 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.0023901 max: 0.484863 deltaT = 1.21285e-05 Time = 6.69519e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 6.69519e-05 transformation: ((0 0 0) (0.999999 (0 -0.00105168 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.999497, 1.02491, 1.00006 AMI: Patch target weights min/max/average = 0.999212, 1.01135, 1.00005 Execution time for mesh.update() = 0.76 s time step continuity errors : sum local = 4.19134e-13, global = -2.48519e-14, cumulative = 1.71693e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 3.53546e-05, No Iterations 5 time step continuity errors : sum local = 1.04974e-15, global = 6.00047e-17, cumulative = 1.71693e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -6.68026e-30 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.23842e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -2.32055e-29 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.00112309, Final residual = 1.93869e-05, No Iterations 2 time step continuity errors : sum local = 2.77824e-09, global = 5.02977e-12, cumulative = 1.71743e-08 GAMG: Solving for p_rgh, Initial residual = 0.000201329, Final residual = 4.32628e-06, No Iterations 2 time step continuity errors : sum local = 6.19553e-10, global = 4.85506e-12, cumulative = 1.71792e-08 GAMGPCG: Solving for p_rgh, Initial residual = 2.98488e-05, Final residual = 4.46162e-09, No Iterations 5 time step continuity errors : sum local = 6.38652e-13, global = -3.95783e-14, cumulative = 1.71791e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.3014e-05, Final residual = 7.2015e-08, No Iterations 1 bounding epsilon, min: -4.3537 max: 9380.48 average: 319.728 DILUPBiCG: Solving for k, Initial residual = 0.00459607, Final residual = 1.00059e-06, No Iterations 2 ExecutionTime = 55.51 s ClockTime = 55 s Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.00246466 max: 0.487793 deltaT = 1.24307e-05 Time = 7.93826e-05 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 7.93826e-05 transformation: ((0 0 0) (0.999999 (0 -0.00124694 0))) AMI: Creating addressing and weights between 6660 source faces and 6660 target faces AMI: Patch source weights min/max/average = 0.99939, 1.02815, 1.00006 AMI: Patch target weights min/max/average = 0.999066, 1.01213, 1.00005 Execution time for mesh.update() = 0.73 s time step continuity errors : sum local = 6.54573e-13, global = -4.05042e-14, cumulative = 1.71791e-08 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 3.58974e-05, No Iterations 6 time step continuity errors : sum local = 1.04694e-15, global = 5.07291e-17, cumulative = 1.71791e-08 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -5.06817e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -3.68502e-29 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.801613 Min(alpha1) = -1.12484e-28 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.000809561, Final residual = 1.5265e-05, No Iterations 2 time step continuity errors : sum local = 2.29045e-09, global = 2.31451e-12, cumulative = 1.71814e-08 GAMG: Solving for p_rgh, Initial residual = 0.000162648, Final residual = 3.58839e-06, No Iterations 2 time step continuity errors : sum local = 5.38243e-10, global = 4.18246e-12, cumulative = 1.71856e-08 GAMGPCG: Solving for p_rgh, Initial residual = 2.49227e-05, Final residual = 3.39738e-09, No Iterations 5 time step continuity errors : sum local = 5.094e-13, global = -3.44719e-14, cumulative = 1.71856e-08 DILUPBiCG: Solving for epsilon, Initial residual = 3.27583e-05, Final residual = 6.98992e-08, No Iterations 1 bounding epsilon, min: -3.47421 max: 8996.31 average: 319.978 DILUPBiCG: Solving for k, Initial residual = 0.00422555, Final residual = 1.25871e-06, No Iterations 2 ExecutionTime = 64.44 s ClockTime = 64 s |
May 5, 2013, 07:59 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sharonyue,
I'm not very experienced on this topic, but I do have a few of questions/comments:
Bruno
May 5, 2013, 09:33 |
#4 | |
Dongyue Li
Rep Power: 17 |
I have read lots of your post,Thats very helpful.Thanks for sharing your CFD experience. Regarding to my case. [*]Which OpenFOAM version are you using? I am using 220 [*]Are you running both in parallel? If so, which decomposition method was used? Yes, I am using simple method in my laptop just for a test. [*]Why is the MRF version referring to AMI? Do the tutorials for MRFInterFoam also refer to AMI in their output? Actually,in MRF, I dont need AMI,but if I want to run the same case in sliding mesh and MRF. I have to use two meshes. While in MRFInterFoam, I can use the mesh with AMI, so I dont need to make another mesh for dynamic solver. [*]Of the 200 million cells, how many cells are moving? In sliding mesh, There are 2127678 cells.Total cell is 2162754. [*]Are you certain that the same volume of fluid is filled on both cases? Yeah,of course,I use the same setFieldsDict. [*]Are there any cyclic patches, symmetry planes and so on? Nope, The majority of em are walls,impeller,Only one outlet. [*]This seems to be too early in the simulation to diagnose which one is fastest... Um...Perhaps I should try it another day for a long runing..? In my laptop, it took about 8 hours calculating 0.08 seconds. |
May 5, 2013, 10:47 |
#5 | |||
Bruno Santos
Rep Power: 128 |
Hi sharonyue,
Roughly 1 or 2 hours each should be more than enough, I guess. But first you better reconfigure the MRF case to not rely on AMI at all, if possible! Best regards, Bruno
May 5, 2013, 19:28 |
#6 | |||
Dongyue Li
Rep Power: 17 |
Is there anything different between this two situation?I regard the result is independent with the rotating cells number. Quote:
Thank you very much.This do me a lot favor~. Regards. |
May 6, 2013, 17:38 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi sharonyue,
For example (all theory here, I have not checked the code!), here's an abstract concept:
If this theory is correct, then there is only one (or a few) remaining explanations as to why AMI was not used in the past: memory! AMI might require a lot more memory than MRF to run. Or perhaps because the algorithm for AMI is a lot more complex... or harder to calibrate... overlapping cells/faces can also be a pain... Best regards, Bruno
May 6, 2013, 20:24 |
#8 | |
Dongyue Li
Rep Power: 17 |
Anyway,this mesh is without AMI.I will try the same mesh with AMI and make a speed test another day.oh my laptop its a pity.. Thanks Bruno. You did a splendid job regarding CFD. BTW, do you have a blog or something? Regards. |
May 7, 2013, 17:34 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi sharonyue,
Here's an interesting read about MRF: http://www.esi-cfd.com/faq/index.php...=19&artlang=en My expertise are in installing OpenFOAM When it comes to CFD, I only know some stuff on the topic The first link in my first signature points to a post to the only blog I've got. Other than that, I've got twitter: @wyldckat Best regards, Bruno
May 7, 2013, 22:58 |
#10 | |
Dongyue Li
Rep Power: 17 |
Regards |
August 22, 2013, 14:33 |
#11 |
Rep Power: 12 |
hi sharonyue,
this topic seems to be same as what i'm doing now. I have done the simulation for centrifugal fan 3D using simpleFoam with mrfZone and it works well. I would like to try this simulation using pimpleDyMFoam which requires me to have AMI. Have you done the one using AMI?? If yes how did you define the AMI? using MRF?? I have read threads regarding the AMI and also the propeller tutorial. In snappyHexMesh there are already faceZone and cellZone being created. Why there is a need to define that again using toposetDict. I hope someone could help me to have a better understanding in continuing my project using pimpleDyMFoam. Btw the simulation using simpleFoam MRF took me a day to be completed using 12 processors (including sHM: cells generated almost 8 000 000) With the assumption from wyldckat that one using pimpleFoam could reduce the time, i would really like to try it and to confirm it.. |
August 22, 2013, 17:21 |
#12 |
Bruno Santos
Rep Power: 128 |
Greetings nash,
Some of the details on this topic are available in this thread: http://www.cfd-online.com/Forums/ope...tml#post446517 namely start reading from post #184 Keep in mind that simpleFoam with MRF gives you a steady-state result. In theory, it should be faster than using pimpleDyMFoam, because this latter solver provides a transient solution with dynamic mesh, which should be several times slower to perform. The comparable differences in wall clock time is only if you compare pimpleFoam+MRF vs pimpleDyMFoam+AMI, because both are transient solvers. And keep in mind that MRF is by definition meant for steady-state (I learned this recently), so be very careful when using MRF in transient simulations. Last but not least:
Bruno
August 23, 2013, 05:31 |
#13 | |
Rep Power: 12 |
thanks Bruno for the explaination.
here is some information i get from the link posted by you: Quote:
Lets say if i want to make the mesh move, i need to use AMI+transient solver which will lead to large simulation time as you mentioned above. Maybe i can run the simulation using transient solver pimpleFoam and compare it with MRF-simpleFoam ( just to confirm the statement from the esi website) Do you have any idea which solver i could also use to simulate this fan (rotor and stator)? Ideas from other foamers are also welcomed thanks |
August 24, 2013, 19:21 |
#14 | |
Bruno Santos
Rep Power: 128 |
Hi nash,
I was following nicely your post until this question: Quote:
Without knowing more about the case in question, it's complicated to suggest anything else. Best regards, Bruno
August 26, 2013, 07:47 |
#15 |
Rep Power: 13 |
In the log files in the first post it can be seen that different solvers are used (DICPCG and GAMG / GAMGPCG). Make sure the solution control is the same for comparison to be valid.
Best regards |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
Incylinder dynamic mesh with volumetric reaction | mas | FLUENT | 4 | May 3, 2012 10:22 |
