Floating point exception (core dumped)
Old   September 1, 2013, 20:04
Exclamation Floating point exception (core dumped)
Joey
Punt3r is on a distinguished road
im very new to Openfoam and am trying to learn it. I want to run a flat plate case to compare to blasius soln. I setup the mesh and initial conditions and geometry (according to my understanding :P)
im trying to run the flat plate case using icoFoam for 1000 iterations with a deltaT of 0.01, so total 10 secs.
so my simulation runs until 1.66 secs i.e. 166 iterations. then at 1.67 i get the following error and dump msg.. ive included the msg frm 1.66 secs for ref if needed..
Time = 1.66
Courant Number mean: 1.03658e+89 max: 1.19227e+91
DILUPBiCG: Solving for Ux, Initial residual = 0.99532, Final residual = 15.6817, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.998739, Final residual = 3.49624, No Iterations 1001
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.47581, No Iterations 1001
time step continuity errors : sum local = 2.97164e+93, global = -1.6172e+91, cumulative = -1.61721e+91
DICPCG: Solving for p, Initial residual = 0.984306, Final residual = 3.82589, No Iterations 1001
time step continuity errors : sum local = 7.6204e+95, global = 2.29239e+93, cumulative = 2.27621e+93
ExecutionTime = 9.87 s ClockTime = 16 s
Time = 1.67
Courant Number mean: 1.5404e+96 max: 1.81873e+98
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/icoFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
I apologize if its something stupid. like i mentioned in my post, im very new and trying to learn on my own... im not completely confident about my case setup also.
Thanks a lot and i appreciate your time...
Punt3r is offline   Reply With Quote
Old   September 3, 2013, 08:51
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Try uploading your case to take a look at.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
blasius, core dumped, flat plate, floating point exception
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
