chtMultiRegionFoam, conduction with a contact resistance between two solids
Old   September 16, 2012, 17:45
Default chtMultiRegionFoam, conduction with a contact resistance between two solids
Romain
romain.h is on a distinguished road
I have a simple test case with 3 solid, and I am trying to solve a simple heat conduction inside those three solids. The third solid should not have any influence for now (see figure)
If I use
type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 300;
        neighbourFieldName T;
        K               solidThermo;
        KName           none;
as in the tutorial, it's working, I have a gradient of DT=q*Rth.
My problem is to introduce an additional resistance, for example a contact resistance between two solids.
I was planning on using the boundary condition fixedGradient, but I have an error when I tried to use such a boundary condition between two solids.
Attempt to cast type fixedGradient to type compressible::turbulentTemperatureCoupledBaffleMixed
Any idea how I can solve my problem ?
Thanks in advance for your help,
Romain
romain.h is offline   Reply With Quote
Old   October 8, 2013, 01:25
pangelo is on a distinguished road
I am a newbie in OF and I am also facing a problem similar to the one Romain posted.
My question: is it possible to set a contact resistance between two solids? (I am using the chtMultiRegionSimpleFoam solver).
Thank you in advance for your answer.
Ciao.
pangelo is offline   Reply With Quote
contact resistance in flotherm Sivan_nk FloEFD, FloWorks & FloTHERM 3 January 13, 2014 23:06
how to use contact resistance model in floEFD eggliang FloEFD, FloWorks & FloTHERM 4 August 5, 2011 00:36
Variable Thermal Contact Resistance octavyo CFX 3 March 13, 2011 11:11
handle thin material or thermal contact resistance sven82 OpenFOAM 3 February 21, 2011 07:43
conduction between 2 different solids matt FLUENT 5 November 9, 2006 08:57
