May 16, 2018, 09:45 |
BCs: WATER TANK WITH INCOMPRESSIBLE SOLVER
#1 | |
Cab
Rep Power: 9 |
I have a doubt regarding what contour conditions to use for the simulation of a water tank.
The simulation runs with the incompressible solver pisoFoam. The tank only counts with the same conduction for the inlet and outlet. In the first instance I try to do a simulation where only the input flow to the deposit is contemplated. This is where I have doubts about which boundary conditions to use. I attach the files of the boundary conditions that I have used. Using these boundary conditions I get the following error: Quote:
Thanks in advance. regards |
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 17:05 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
Shallow Water Equations: Roe Approximate Solver First-Order with Wetting-Drying | mhallsmoore | Main CFD Forum | 2 | December 20, 2016 13:50 |
[GAMBIT] Water Slosing in Water Tank | iwan | ANSYS Meshing & Geometry | 4 | October 17, 2013 18:25 |
Problems with BCs in muliphase flow with water falling from a reservoir | Paul_l | FLUENT | 2 | March 11, 2011 04:59 |
