October 16, 2013, 12:28 |
Falling Droplet using InterFoam
Kostis
Rep Power: 13 |
Hi guys,
I am trying to simulate a 3D droplet falling due to gravity forces with interFoam as simple as that. When the droplet reaches a velocity I will put it in a jet flow using mapFields. I have encountered some strange things and I cant even do the first part. a) Should I change the pressure inside the droplet due to the surface tension? p=2*sigma/r. What about the distribution of pressure inside the droplet due to gravity? b) Do you believe that the outcome would be the same if I enter a velocity in funkySetFieldsDict? c) Finally, the droplet disintergrates very quickly before it reaches the velocity (1m/s) which is totally unnatural. Why is that? (personally, I do not think it is about contact angle) Thank you for you time Kostis |
November 12, 2013, 18:22 |
Shawn Fotovati
Rep Power: 16 |
You should not change the pressure. Solver must calculate it during the solution.
If droplet disintegrates, I believe it is due to mesh, change the mesh and see if it is improved. I have another problem; Right before droplet hits the surface, it stops moving, and hangs around in the air! I have no idea why this happens for my case! |
December 2, 2013, 17:30 |
cosbergel, I have been having trouble with a 3D droplet behaving almost the same way you described. My grid is refined to .1mm spacing for a 2mm droplet which I thought was sufficient. An order of magnitude refinement did not help. Were you able to figure out your problem? I was using multiphaseInterFoam, but the advice should probably be similar for both.
I appreciate any help! |
December 3, 2013, 05:15 |
Kostis
Rep Power: 13 |
@ sfotovati as far as the pressure is concerned, you are right that the solver calculates the pressure inside the droplet but I found out that it is better to put it as an initial condition because otherwise you ll have perturbations on the surface of the droplet.
I think that you have put wrong boundary condition on the wall. @btsusi I manage to solve my problem firstly by not using dynamic refinement and then by changing the div schemes (specially for alpha1) for interFoam and interDyMFoam which I had it finally working. In my opinion satisfactory number of cells inside a droplet is 50- 100. Regards, Kostis |
December 3, 2013, 09:10 |
cosbergel,
Thank you for the quick response, I will try your advice! |
May 16, 2018, 05:21 |
#6 | |
Saicharan
Rep Power: 8 |
Modelling falling solid sphere using interFoam VOF model | eelcovv | OpenFOAM Running, Solving & CFD | 6 | August 7, 2021 21:52 |
droplet falling - VOF | bohis | FLUENT | 1 | July 10, 2013 04:28 |
falling droplet deforms unusually- Multiphase | MNHasan | FLUENT | 2 | July 10, 2013 04:25 |
sphere falling down droplet | naderafshar | FLUENT | 1 | December 24, 2011 10:30 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
