July 2, 2013, 12:57 |
Moving Heat Source on a CV
Rep Power: 12 |
Hello together,
I'm completely new in using OpenFoam and faced with a (I hope simple) problem I don't know how to continue. My case is to simulate a simple heat conduction welding process where I want to simulate in a first step a moving heat source (Point source or circle) on the surface of a control volume (CV). I've chosen the laplacianFOAM solver because I don't want to consider any convective parts. For that issue. I've implemented a source term q in the standard laplacianFOAM solver and boundaries. But how is the approach for using this term as a moving source? Do I need a moving "meshgrid" on the CV or maybe inside (Volume source) or can I solve this by boundary conditions? Thanks a lot for answers. Tomster |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
Moving workpiece instead of Heat source Problem | ahmmedshakil | OpenFOAM Programming & Development | 1 | April 20, 2013 23:17 |
