Moving Heat Source on a CV
Like Tree1Likes
  • 1 Post By ahmmedshakil
Old   July 2, 2013, 12:57
Default Moving Heat Source on a CV
Tomster0815 is on a distinguished road
Hello together,
I'm completely new in using OpenFoam and faced with a (I hope simple) problem I don't know how to continue.
My case is to simulate a simple heat conduction welding process where I want to simulate in a first step a moving heat source (Point source or circle) on the surface of a control volume (CV). I've chosen the laplacianFOAM solver because I don't want to consider any convective parts.
For that issue. I've implemented a source term q in the standard laplacianFOAM solver and boundaries.
But how is the approach for using this term as a moving source?
Do I need a moving "meshgrid" on the CV or maybe inside (Volume source) or can I solve this by boundary conditions?
Thanks a lot for answers.
Tomster
Tomster0815 is offline   Reply With Quote
Old   July 3, 2013, 14:21
Default Update: Maybe fvOptions as a solution?
Hello again,
after one more day of searching on a lot of sites I found an approach for my problem using the fvOptions framework.
I'll try it with the simpleScalarFOAM because the solver includes a fvOptions (T) - source-term.
Anyway - does anybody have a good conclusion or an idea where I can find a "manual" how I've to set der fvOptions dictionary file to create a moving heat source?
Thanks again for any reply.
Old   July 3, 2013, 21:42
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
Hi Tomster,
It's easy to model the moving heat source. If your heat source is a surface heat source, then you can impose it as a boundary condition, then groovyBC [http://openfoamwiki.net/index.php/Contrib_groovyBC] will be more helpful for you. Just look at the groovyBC sites.
In case of volumetric heat source, you can easily use "expressionSource"- which comes with the swak4Foam [http://openfoamwiki.net/index.php/Contrib/swak4Foam].
So, what you need to construct the expression for moving source, then use the method that comply your need.
Cheers!
ahmmedshakil is offline   Reply With Quote
Old   July 8, 2013, 12:00
Default How to implement something from swak4Foam?
Hey Ahmmedshakil,
thanks a lot for you suggestion!
I'm completely new in OpenFoam and I have after a couple of days reading no idea how I have to implement this function I'm sorry, but the structure of OF is not easy to understand...
In the first step, I've downloaded and compiled swak4foam (with ./Allwmake). But where and how do I have to implement the Code? I want to use your suggested expressionSource.H for adding a moving volumetric heat source.
- Is the source itself (size, moving parameters) described in a library in the run/case-folder?
- Do I have to change something in the laplacianFoam.C?
- Should I add something in the ./Make/files oder options-file?
- What is to to in the case-folder?
Thank you for answering my noob-questions
Greetings, Tomster
Old   July 9, 2013, 02:40
Hi Tomster,
For using expressionSource, there is a example done in swak4Foam-->Examples-->interFoamWithSources. And you can easily take help from this post: http://www.cfd-online.com/Forums/ope...urce-term.html.
Cheers!
Old   July 9, 2013, 09:10
Default How does it work?
Hello Ahmmedshakil,
thank you again for replying my post. Unfortunately it does not work
I'll now exactly describe what I've done from the beginning - maybe you find my mistake:
- I've downloaded the swak4Foam files (Version 0.2.3) from http://openfoamwiki.net/index.php/Contrib/swak4Foam as a *.tar-file and unpacked it in the $HOME/swak4foam directory (and stayed the files later here)
- As mentioned, I commented out the
#define FOAM_LOOKUPCLASS_NO_CONST
in the Libraries/swak4FoamParsers/include/swak.H file
- I compiled swak4Foam with ./Allwmake (It took around 10 Minutes!?)
- For my case, I followed the instructions from gschaider in this post: http://www.cfd-online.com/Forums/ope...urce-term.html
- Now these are my files:
createFields.H
Info<< "Reading field T\n" << endl;
    volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
//----NEUE WAERMEQUELLE HINZUFUEGEN----
 expressionSource<scalar> heaterSource
 IOdictionary
        IOobject
            "heaterSourceDict",
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
        mesh
    Info<< "Reading transportProperties\n" << endl;
    IOdictionary transportProperties
        IOobject
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    Info<< "Reading diffusivity DT\n" << endl;
    dimensionedScalar DT
        transportProperties.lookup("DT")
laplacianFoam.C
#include "fvCFD.H"
#include "simpleControl.H"
#include "expressionSource.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    simpleControl simple(mesh);
    Info<< "\nCalculating temperature distribution\n" << endl;
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        while (simple.correctNonOrthogonal())
            solve
  //Original: fvm::ddt(T) - fvm::laplacian(DT, T)
                  fvm::ddt(T)
  heaterSource()
        #include "write.H"
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
and the ./Make/options
EXE_INC = \
          -I$(LIB_SRC)/finiteVolume/lnInclude \
          -I$HOME/swak4Foam/Libraries/swakSourceFields/InInclude
EXE_LIBS = \
    -lfiniteVolume \
           -L$FOAM_USER_LIBBIN
- I've tried to compile it with wmake but it didn't work (Error Message: expressionSource.H not found). Is my "link" in the options file incorrect written or where do I have to copy the EXE- and LIB-Files from swak4Foam?
Another Problem is that I can't run the suggested Example in ./interFoamWithSources. What do I have to do that it will work?
Thank you again very much - I hope my questions will help other noobs in understanding OpenFoam with swak4Foam
(Afer success I'll publish my code here).
Greetings
Old   July 9, 2013, 21:25
Hi Tomster,
The error message Error Message: expressionSource.H not found)--- so you have problem in the linking file i.e.
EXE_INC = \
(PLEASE CHECK HERE)
EXE_LIBS = \
-lfiniteVolume \
-L$FOAM_USER_LIBBIN
The same thing is true for the example running.... I'm sure now you can run the solver.
cheers!!
raj kumar saini likes this.
Old   November 3, 2013, 03:30
Default transient heat source
Kumudu
Kumudu is on a distinguished road
Where u defined the heatSourceDict and how. I am new to OpenFoam and please tell me the step you follow to add the transient heat source into LaplacianFoam.
Kumudu
Originally Posted by Tomster0815 View Post
Hello Ahmmedshakil,
createFields.H
    volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
        mesh
 IOdictionary
        IOobject
            "heaterSourceDict",
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
        mesh
        IOobject
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
laplacianFoam.C
#include "fvCFD.H"
            solve
                  fvm::ddt(T)
  heaterSource()
        #include "write.H"
            << nl << endl;
    return 0;
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
           -L$FOAM_USER_LIBBIN
Greetings
Kumudu is offline   Reply With Quote
Old   November 3, 2013, 04:10
Default Transient heat source
Kumudu
Hi Tomster0815,
I did exactly what you said. But I got this error. Please tell me how to fix this.
Kumudu
kumudu21688@kumudu21688-Inspiron-N5040:~/OpenFOAM/kumudu21688-2.1.1/run/myheatsource$ mylaplacianFoam
| \\ / O peration | Version: 2.1.1 |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : mylaplacianFoam
Date : Nov 03 2013
Time : 11:01:29
Host : "kumudu21688-Inspiron-N5040"
PID : 4536
Case : /home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/run/myheatsource
nProcs : 1
Create time
Create mesh for time = 0
Reading field T
SIMPLE: no convergence criteria found. Calculations will run for 15 steps.
swak4Foam: Allocating new repository for sampledSets
--> FOAM FATAL IO ERROR:
Attempt to return dictionary entry as a primitive
file: /home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/run/myheatsource/system/controlDict::functions::theSensor::setName from line 59 to line 63.
From function ITstream& primitiveEntry::stream() const
in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 82.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::IOerror::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::dictionaryEntry::stream() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::SetsRepository::getSet(Foam::dictionary const&, Foam:olyMesh const&) in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#4 Foam::createSampledSet::createSampledSet(Foam::wor d const&, Foam:bjectRegistry const&, Foam::dictionary const&, bool) in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#5 Foam::OutputFilterFunctionObject<Foam::createSampl edSet>::allocateFilter() in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#6 Foam::OutputFilterFunctionObject<Foam::createSampl edSet>::start() in "/home/kumudu21688/OpenFOAM/kumudu21688-2.1.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#7 Foam::functionObjectList::read() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#8 Foam::Time::run() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#9 Foam::Time::loop() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#10 Foam::simpleControl::loop() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#11
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/mylaplacianFoam"
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
Aborted (core dumped)
Hello Ahmmedshakil,
createFields.H
    volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
        mesh
 IOdictionary
        IOobject
            "heaterSourceDict",
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
        mesh
        IOobject
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
laplacianFoam.C
#include "fvCFD.H"
            solve
                  fvm::ddt(T)
  heaterSource()
        #include "write.H"
            << nl << endl;
    return 0;
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
           -L$FOAM_USER_LIBBIN
Greetings
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Moving workpiece instead of Heat source Problem ahmmedshakil OpenFOAM Programming & Development 1 April 20, 2013 23:17
