[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04
Old   December 24, 2013, 04:30
Default Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04
kobayashi is on a distinguished road
I’d liked to use OpenFOAM1.7.1 on Ubuntu 13.04/13.10.
And I need to use user defined library swak4Foam.
I installed OpenFOAM1.7.1 on Ubuntu 13.04 successfully but I couldn’t install swak4Foam.
Here is the specific steps of installation:
Step1: Install svn, bison
sudo apt-get install subversion
sudo apt-get install bison
Step2: Add OpenFOAM1.7.1 to openfoam install list
sudo su
gedit /etc/apt/sources.list.d/openfoam.list
"SAVE THE TEXT AFTER REWRITE AS BELOW"
deb http://www.openfoam.org/download/ubuntu maverick main
sudo apt-get update
Step3: Install OpenFOAM
sudo apt-get install openfoam171
gedit ~/.bashrc
"ADD THE LINE BELOW"
. /opt/openfoam171/etc/bashrc
Step4: Download swak4Foam
run
cd ../
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_1.7/libraries/swak4Foam/
Step5: Install swak4Foam
cd swak4Foam
. Allwmake
Through Step1-4 I have no problem, but I got error message like the attached log file at Step5 and cannot continue installation.
I'd like to know the reason/cause of the error.
I'd like to know if it's possible to solve this problem or I have to downgrade Ubuntu.
If calculation runs, are the simulation results trustworthy?
Thank you for your help.
kobayashi is offline   Reply With Quote
Old   December 25, 2013, 06:08
Retired Super Moderator
Bruno Santos
Greetings kobayashi and welcome to the forum!
Is there any chance you can change to OpenFOAM 1.7.x? Because 1.7.1 is really old by now and there were several modifications made after 1.7.1 was released and are available in 1.7.x.
If you cannot switch to the more recent OpenFOAM 1.7.x, I'll try to have a better look into this.
Better yet would be if you could use the latest OpenFOAM 2.2 series, but I suppose you cannot do so.
Best regards,
Bruno
Old   January 5, 2014, 17:33
Assistant Moderator
Bernhard Gschaider
sudo su
sudo apt-get update
gedit ~/.bashrc
run
cd ../
cd swak4Foam
. Allwmake
The problem is not with swak but with the OF sources and your compiler not reacting good to it.
Seems that the compiler on your system (you're using binaries that were compiled on a much older system) doesn't like the call of methods of a parent class in a template without this-> before it (he even says so). In fact: when checking wit 2.2.x the "insert()"-calls were replaced with "this->insert()" in HashPtrTableIO.C. You can try fixing that there, but I'm afraid you'll run into similar problems later. But as I said: this is not a swak-problem. You'll have to fix your OpenFOAM-sources
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
error, installation, openfoam 1.7.1, swak4foam, ubuntu 13.04
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS matheusmonjon OpenFOAM Installation 3 February 25, 2017 14:46
[swak4Foam] [OpenFOAM] [2.3.1] Install swak4Foam in Ubuntu 16.04.01 with errors ycui OpenFOAM Community Contributions 2 November 14, 2016 07:41
[swak4Foam] Installing swak4Foam 0.4.0 on ubuntu 14.04 JFM OpenFOAM Community Contributions 1 October 30, 2016 09:43
Environment errors with .deb install and ubuntu 13.04 64 bit jonathanbyrn OpenFOAM Installation 14 September 26, 2013 05:22
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
