December 8, 2013, 08:13
FATAL ERROR:Maximum number of iterations exceeded
赵庆良
Foamers,
Hi,I have a problem.At firt,I ran my case(CH4 combustion) and there is no problem.The temperature rises and iterations calculate nomally.But when calculated above temperature 1365K,it gave me a fatal error as following:
acer@ubuntu:~/OpenFOAM/acer-2.2.2/run/singlefirepoolorg$ [0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Maximum number of iterations exceeded
[0]
[0] From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[0] in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
[0]
FOAM parallel run aborting
[0]
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::error::abort() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2 Foam::species::thermo<Foam::janafThermo<Foam:erf ectGas<Foam::specie> >, Foam::absoluteEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::janafThermo<Foam:er fectGas<Foam::specie> >, Foam::absoluteEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::janafThermo<Foam:er fectGas<Foam::specie> >, Foam::absoluteEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::janafThermo<Foam:er fectGas<Foam::specie> >, Foam::absoluteEnthalpy>::*)(double) const) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so"
[0] #3 Foam::hePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::su therlandTransport<Foam::species::thermo<Foam::jana fThermo<Foam:erfectGas<Foam::specie> >, Foam::absoluteEnthalpy> > > > >::calculate() in "/home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so"
[0] #4 Foam::hePsiThermo<Foam:siReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::su therlandTransport<Foam::species::thermo<Foam::jana fThermo<Foam:erfectGas<Foam::specie> >, Foam::absoluteEnthalpy> > > > >::correct() in "/home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so"
[0] #5
[0] in "/home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/bin/buoyantFireFoamorg"
[0] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #7
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
*** glibc detected *** buoyantFireFoamorg: corrupted double-linked list: 0x0000000000f984a0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7f820167cb96]
/lib/x86_64-linux-gnu/libc.so.6(+0x7ef00)[0x7f820167cf00]
/lib/x86_64-linux-gnu/libc.so.6(+0x7fb29)[0x7f820167db29]
/lib/x86_64-linux-gnu/libc.so.6(+0x3b968)[0x7f8201639968]
/lib/x86_64-linux-gnu/libc.so.6(+0x3b985)[0x7f8201639985]
/usr/lib/libopen-rte.so.0(orte_ess_base_app_abort+0x20)[0x7f81fef5e200]
/usr/lib/libopen-rte.so.0(orte_errmgr_base_error_abort+0xfd)[0x7f81fef5d73d]
/usr/lib/libmpi.so.0(ompi_mpi_abort+0x255)[0x7f81ff1bbec5]
/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x1c6)[0x7f82025c9cd6]
/opt/openfoam222/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so(_ZNK4Foam7speci es6thermoINS_11janafThermoINS_10perfectGasINS_6spe cieEEEEENS_16absoluteEnthalpyEE1TEdddMS8_KFdddESA_ MS8_KFddE+0x19c)[0x7f82055aca5c]
/home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so(_ZN4Foam11hePsiThermoINS_17psiReact ionThermoENS_13SpecieMixtureINS_15reactingMixtureI NS_19sutherlandTransportINS_7species6thermoINS_11j anafThermoINS_10perfectGasINS_6specieEEEEENS_16abs oluteEnthalpyEEEEEEEEEE9calculateEv+0x2b7)[0x7f81fa865657]
/home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so(_ZN4Foam11hePsiThermoINS_17psiReact ionThermoENS_13SpecieMixtureINS_15reactingMixtureI NS_19sutherlandTransportINS_7species6thermoINS_11j anafThermoINS_10perfectGasINS_6specieEEEEENS_16abs oluteEnthalpyEEEEEEEEEE7correctEv+0x32)[0x7f81fa87d8c2]
buoyantFireFoamorg[0x431e69]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7f820161f76d]
buoyantFireFoamorg[0x440a1d]
======= Memory map: ========
00400000-004cb000 r-xp 00000000 07:00 410661 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/bin/buoyantFireFoamorg
006ca000-006cd000 r--p 000ca000 07:00 410661 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/bin/buoyantFireFoamorg
006cd000-006ce000 rw-p 000cd000 07:00 410661 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/bin/buoyantFireFoamorg
00e23000-0fab1000 rw-p 00000000 00:00 0 [heap]
7f81f24ed000-7f81f4bc3000 rw-p 00000000 00:00 0
7f81f4bc3000-7f81f8bc5000 rw-s 00000000 07:00 356545 /tmp/openmpi-sessions-acer@ubuntu_0/2104/1/shared_mem_pool.ubuntu (deleted)
7f81f8bc5000-7f81f8bd2000 r-xp 00000000 07:00 330798 /usr/lib/openmpi/lib/openmpi/mca_osc_rdma.so
7f81f8bd2000-7f81f8dd1000 ---p 0000d000 07:00 330798 /usr/lib/openmpi/lib/openmpi/mca_osc_rdma.so
7f81f8dd1000-7f81f8dd2000 r--p 0000c000 07:00 330798 /usr/lib/openmpi/lib/openmpi/mca_osc_rdma.so
7f81f8dd2000-7f81f8dd3000 rw-p 0000d000 07:00 330798 /usr/lib/openmpi/lib/openmpi/mca_osc_rdma.so
7f81f8dd3000-7f81f8ddd000 r-xp 00000000 07:00 330797 /usr/lib/openmpi/lib/openmpi/mca_osc_pt2pt.so
7f81f8ddd000-7f81f8fdc000 ---p 0000a000 07:00 330797 /usr/lib/openmpi/lib/openmpi/mca_osc_pt2pt.so
7f81f8fdc000-7f81f8fdd000 r--p 00009000 07:00 330797 /usr/lib/openmpi/lib/openmpi/mca_osc_pt2pt.so
7f81f8fdd000-7f81f8fde000 rw-p 0000a000 07:00 330797 /usr/lib/openmpi/lib/openmpi/mca_osc_pt2pt.so
7f81f8fde000-7f81f8ff5000 r-xp 00000000 07:00 330771 /usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so
7f81f8ff5000-7f81f91f4000 ---p 00017000 07:00 330771 /usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so
7f81f91f4000-7f81f91f5000 r--p 00016000 07:00 330771 /usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so
7f81f91f5000-7f81f91f6000 rw-p 00017000 07:00 330771 /usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so
7f81f91f6000-7f81f91f9000 r-xp 00000000 07:00 330770 /usr/lib/openmpi/lib/openmpi/mca_coll_sync.so
7f81f91f9000-7f81f93f8000 ---p 00003000 07:00 330770 /usr/lib/openmpi/lib/openmpi/mca_coll_sync.so
7f81f93f8000-7f81f93f9000 r--p 00002000 07:00 330770 /usr/lib/openmpi/lib/openmpi/mca_coll_sync.so
7f81f93f9000-7f81f93fa000 rw-p 00003000 07:00 330770 /usr/lib/openmpi/lib/openmpi/mca_coll_sync.so
7f81f93fa000-7f81f93ff000 r-xp 00000000 07:00 330769 /usr/lib/openmpi/lib/openmpi/mca_coll_sm.so
7f81f93ff000-7f81f95fe000 ---p 00005000 07:00 330769 /usr/lib/openmpi/lib/openmpi/mca_coll_sm.so
7f81f95fe000-7f81f95ff000 r--p 00004000 07:00 330769 /usr/lib/openmpi/lib/openmpi/mca_coll_sm.so
7f81f95ff000-7f81f9600000 rw-p 00005000 07:00 330769 /usr/lib/openmpi/lib/openmpi/mca_coll_sm.so
7f81f9600000-7f81f9602000 r-xp 00000000 07:00 330768 /usr/lib/openmpi/lib/openmpi/mca_coll_self.so
7f81f9602000-7f81f9801000 ---p 00002000 07:00 330768 /usr/lib/openmpi/lib/openmpi/mca_coll_self.so
7f81f9801000-7f81f9802000 r--p 00001000 07:00 330768 /usr/lib/openmpi/lib/openmpi/mca_coll_self.so
7f81f9802000-7f81f9803000 rw-p 00002000 07:00 330768 /usr/lib/openmpi/lib/openmpi/mca_coll_self.so
7f81f9803000-7f81f9806000 r-xp 00000000 07:00 330767 /usr/lib/openmpi/lib/openmpi/mca_coll_inter.so
7f81f9806000-7f81f9a05000 ---p 00003000 07:00 330767 /usr/lib/openmpi/lib/openmpi/mca_coll_inter.so
7f81f9a05000-7f81f9a06000 r--p 00002000 07:00 330767 /usr/lib/openmpi/lib/openmpi/mca_coll_inter.so
7f81f9a06000-7f81f9a07000 rw-p 00003000 07:00 330767 /usr/lib/openmpi/lib/openmpi/mca_coll_inter.so
7f81f9a07000-7f81f9a0b000 r-xp 00000000 07:00 330766 /usr/lib/openmpi/lib/openmpi/mca_coll_hierarch.so
7f81f9a0b000-7f81f9c0a000 ---p 00004000 07:00 330766 /usr/lib/openmpi/lib/openmpi/mca_coll_hierarch.so
7f81f9c0a000-7f81f9c0b000 r--p 00003000 07:00 330766 /usr/lib/openmpi/lib/openmpi/mca_coll_hierarch.so
7f81f9c0b000-7f81f9c0c000 rw-p 00004000 07:00 330766 /usr/lib/openmpi/lib/openmpi/mca_coll_hierarch.so
7f81f9c0c000-7f81f9c14000 r-xp 00000000 07:00 330765 /usr/lib/openmpi/lib/openmpi/mca_coll_basic.so
7f81f9c14000-7f81f9e13000 ---p 00008000 07:00 330765 /usr/lib/openmpi/lib/openmpi/mca_coll_basic.so
7f81f9e13000-7f81f9e14000 r--p 00007000 07:00 330765 /usr/lib/openmpi/lib/openmpi/mca_coll_basic.so
7f81f9e14000-7f81f9e15000 rw-p 00008000 07:00 330765 /usr/lib/openmpi/lib/openmpi/mca_coll_basic.so
7f81f9e15000-7f81f9e20000 r-xp 00000000 07:00 330762 /usr/lib/openmpi/lib/openmpi/mca_btl_tcp.so
7f81f9e20000-7f81fa01f000 ---p 0000b000 07:00 330762 /usr/lib/openmpi/lib/openmpi/mca_btl_tcp.so
7f81fa01f000-7f81fa020000 r--p 0000a000 07:00 330762 /usr/lib/openmpi/lib/openmpi/mca_btl_tcp.so
7f81fa020000-7f81fa021000 rw-p 0000b000 07:00 330762 /usr/lib/openmpi/lib/openmpi/mca_btl_tcp.so
7f81fa021000-7f81fa0a1000 rw-p 00000000 00:00 0
7f81fa0a1000-7f81fa0a6000 r-xp 00000000 07:00 330761 /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so
7f81fa0a6000-7f81fa2a5000 ---p 00005000 07:00 330761 /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so
7f81fa2a5000-7f81fa2a6000 r--p 00004000 07:00 330761 /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so
7f81fa2a6000-7f81fa2a7000 rw-p 00005000 07:00 330761 /usr/lib/openmpi/lib/openmpi/mca_btl_sm.so
7f81fa2a7000-7f81fa2aa000 r-xp 00000000 07:00 330760 /usr/lib/openmpi/lib/openmpi/mca_btl_self.so
7f81fa2aa000-7f81fa4a9000 ---p 00003000 07:00 330760 /usr/lib/openmpi/lib/openmpi/mca_btl_self.so
7f81fa4a9000-7f81fa4aa000 r--p 00002000 07:00 330760 /usr/lib/openmpi/lib/openmpi/mca_btl_self.so
7f81fa4aa000-7f81fa4ab000 rw-p 00003000 07:00 330760 /usr/lib/openmpi/lib/openmpi/mca_btl_self.so
7f81fa7d8000-7f81fa8dd000 r-xp 00000000 07:00 479396 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so
7f81fa8dd000-7f81faadc000 ---p 00105000 07:00 479396 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so
7f81faadc000-7f81faae2000 r--p 00104000 07:00 479396 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so
7f81faae2000-7f81faae4000 rw-p 0010a000 07:00 479396 /home/acer/OpenFOAM/acer-2.2.2/platforms/linux64GccDPOpt/lib/libmyThermo.so
7f81faae4000-7f81faae8000 r-xp 00000000 07:00 330757 /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so
7f81faae8000-7f81face7000 ---p 00004000 07:00 330757 /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so
7f81face7000-7f81face8000 r--p 00003000 07:00 330757 /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so
7f81face8000-7f81face9000 rw-p 00004000 07:00 330757 /usr/lib/openmpi/lib/openmpi/mca_bml_r2.so
7f81faeed000-7f81faf00000 r-xp 00000000 07:00 330806 /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so
7f81faf00000-7f81fb100000 ---p 00013000 07:00 330806 /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so
7f81fb100000-7f81fb101000 r--p 00013000 07:00 330806 /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so
7f81fb101000-7f81fb102000 rw-p 00014000 07:00 330806 /usr/lib/openmpi/lib/openmpi/mca_pml_ob1.so
7f81fb31e000-7f81fb323000 r-xp 00000000 07:00 330775 /usr/lib/openmpi/lib/openmpi/mca_dpm_orte.so
7f81fb323000-7f81fb522000 ---p 00005000 07:00 330775 /usr/lib/openmpi/lib/openmpi/mca_dpm_orte.so
7f81fb522000-7f81fb523000 r--p 00004000 07:00 330775 /usr/lib/openmpi/lib/openmpi/mca_dpm_orte.so
7f81fb523000-7f81fb524000 rw-p 00005000 07:00 330775 /usr/lib/openmpi/lib/openmpi/mca_dpm_orte.so
7f81fb524000-7f81fb527000 r-xp 00000000 07:00 330808 /usr/lib/openmpi/lib/openmpi/mca_pubsub_orte.so
7f81fb527000-7f81fb726000 ---p 00003000 07:00 330808 /usr/lib/openmpi/lib/openmpi/mca_pubsub_orte.so
7f81fb726000-7f81fb727000 r--p 00002000 07:00 330808 /usr/lib/openmpi/lib/openmpi/mca_pubsub_orte.so
7f81fb727000-7f81fb728000 rw-p 00003000 07:00 330808 /usr/lib/openmpi/lib/openmpi/mca_pubsub_orte.so
7f81fb728000-7f81fb72a000 r-xp 00000000 07:00 329784 /usr/lib/openmpi/lib/libmca_common_sm.so.1.0.0
7f81fb72a000-7f81fb929000 ---p 00002000 07:00 329784 /usr/lib/openmpi/lib/libmca_common_sm.so.1.0.0
7f81fb929000-7f81fb92a000 r--p 00001000 07:00 329784 /usr/lib/openmpi/lib/libmca_common_sm.so.1.0.0
7f81fb92a000-7f81fb92b000 rw-p 00002000 07:00 329784 /usr/lib/openmpi/lib/libmca_common_sm.so.1.0.0
7f81fb92b000-7f81fb92d000 r-xp 00000000 07:00 330793 /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so
7f81fb92d000-7f81fbb2c000 ---p 00002000 07:00 330793 /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so
7f81fbb2c000-7f81fbb2d000 r--p 00001000 07:00 330793 /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so
7f81fbb2d000-7f81fbb2e000 rw-p 00002000 07:00 330793 /usr/lib/openmpi/lib/openmpi/mca_mpool_sm.so
7f81fbb2e000-7f81fbb31000 r-xp 00000000 07:00 330792 /usr/lib/openmpi/lib/openmpi/mca_mpool_rdma.so
7f81fbb31000-7f81fbd30000 ---p 00003000 07:00 330792 /usr/lib/openmpi/lib/openmpi/mca_mpool_rdma.so
7f81fbd30000-7f81fbd31000 r--p 00002000 07:00 330792 /usr/lib/openmpi/lib/openmpi/mca_mpool_rdma.so
7f81fbd31000-7f81fbd32000 rw-p 00003000 07:00 330792 /usr/lib/openmpi/lib/openmpi/mca_mpool_rdma.so
7f81fbd32000-7f81fbd33000 r-xp 00000000 07:00 330791 /usr/lib/openmpi/lib/openmpi/mca_mpool_fake.so
7f81fbd33000-7f81fbf32000 ---p 00001000 07:00 330791 /usr/lib/openmpi/lib/openmpi/mca_mpool_fake.so
7f81fbf32000-7f81fbf33000 r--p 00000000 07:00 330791 /usr/lib/openmpi/lib/openmpi/mca_mpool_fake.so
7f81fbf33000-7f81fbf34000 rw-p 00001000 07:00 330791 /usr/lib/openmpi/lib/openmpi/mca_mpool_fake.so
7f81fbf34000-7f81fbf37000 r-xp 00000000 07:00 330811 /usr/lib/openmpi/lib/openmpi/mca_rcache_vma.so
7f81fbf37000-7f81fc136000 ---p 00003000 07:00 330811 /usr/lib/openmpi/lib/openmpi/mca_rcache_vma.so
7f81fc136000-7f81fc137000 r--p 00002000 07:00 330811 /usr/lib/openmpi/lib/openmpi/mca_rcache_vma.so
7f81fc137000-7f81fc138000 rw-p 00003000 07:00 330811 /usr/lib/openmpi/lib/openmpi/mca_rcache_vma.so
7f81fc138000-7f81fc13a000 r-xp 00000000 07:00 330756 /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so
7f81fc13a000-7f81fc339000 ---p 00002000 07:00 330756 /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so
7f81fc339000-7f81fc33a000 r--p 00001000 07:00 330756 /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so
7f81fc33a000-7f81fc33b000 rw-p 00002000 07:00 330756 /usr/lib/openmpi/lib/openmpi/mca_allocator_bucket.so
7f81fc33b000-7f81fc33d000 r-xp 00000000 07:00 330755 /usr/lib/openmpi/lib/openmpi/mca_allocator_basic.so
7f81fc33d000-7f81fc53c000 ---p 00002000 07:00 330755 /usr/lib/openmpi/lib/openmpi/mca_allocator_basic.so
7f81fc53c000-7f81fc53d000 r--p 00001000 07:00 330755 /usr/lib/openmpi/lib/openmpi/mca_allocator_basic.so
7f81fc53d000-7f81fc53e000 rw-p 00002000 07:00 330755 /usr/lib/openmpi/lib/openmpi/mca_allocator_basic.so
7f81fc53e000-7f81fc54a000 r-xp 00000000 07:00 234599 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f81fc54a000-7f81fc749000 ---p 0000c000 07:00 234599 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f81fc749000-7f81fc74a000 r--p 0000b000 07:00 234599 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f81fc74a000-7f81fc74b000 rw-p 0000c000 07:00 234599 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7f81fc74b000-7f81fc755000 r-xp 00000000 07:00 234508 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f81fc755000-7f81fc955000 ---p 0000a000 07:00 234508 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f81fc955000-7f81fc956000 r--p 0000a000 07:00 234508 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f81fc956000-7f81fc957000 rw-p 0000b000 07:00 234508 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7f81fc957000-7f81fc95f000 r-xp 00000000 07:00 234598 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f81fc95f000-7f81fcb5e000 ---p 00008000 07:00 234598 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f81fcb5e000-7f81fcb5f000 r--p 00007000 07:00 234598 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f81fcb5f000-7f81fcb60000 rw-p 00008000 07:00 234598 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7f81fcb60000-7f81fcb64000 r-xp 00000000 07:00 330818 /usr/lib/openmpi/lib/openmpi/mca_routed_binomial.so
7f81fcb64000-7f81fcd63000 ---p 00004000 07:00 330818 /usr/lib/openmpi/lib/openmpi/mca_routed_binomial.so
7f81fcd63000-7f81fcd64000 r--p 00003000 07:00 330818 /usr/lib/openmpi/lib/openmpi/mca_routed_binomial.so
7f81fcd64000-7f81fcd65000 rw-p 00004000 07:00 330818 /usr/lib/openmpi/lib/openmpi/mca_routed_binomial.so
7f81fcd65000-7f81fcd74000 r-xp 00000000 07:00 330796 /usr/lib/openmpi/lib/openmpi/mca_oob_tcp.so
7f81fcd74000-7f81fcf73000 ---p 0000f000 07:00 330796 /usr/lib/openmpi/lib/openmpi/mca_oob_tcp.so
7f81fcf73000-7f81fcf74000 r--p 0000e000 07:00 330796 /usr/lib/openmpi/lib/openmpi/mca_oob_tcp.so
7f81fcf74000-7f81fcf75000 rw-p 0000f000 07:00 330796 /usr/lib/openmpi/lib/openmpi/mca_oob_tcp.so
7f81fcf75000-7f81fcf7a000 r-xp 00000000 07:00 330817 /usr/lib/openmpi/lib/openmpi/mca_rml_oob.so
7f81fcf7a000-7f81fd179000 ---p 00005000 07:00 330817 /usr/lib/openmpi/lib/openmpi/mca_rml_oob.so
7f81fd179000-7f81fd17a000 r--p 00004000 07:00 330817 /usr/lib/openmpi/lib/openmpi/mca_rml_oob.so
7f81fd17a000-7f81fd17b000 rw-p 00005000 07:00 330817 /usr/lib/openmpi/lib/openmpi/mca_rml_oob.so
7f81fd17b000-7f81fd17e000 r-xp 00000000 07:00 330783 /usr/lib/openmpi/lib/openmpi/mca_grpcomm_bad.so[ubuntu:02668] *** Process received signal ***
[ubuntu:02668] Signal: Aborted (6)
[ubuntu:02668] Signal code: (-6)
The error indicated that Maximum number of iterations exceeded.Then I found the thermoI.H according to the error.
There is a inline function in thermoI.H in the following:
template<class Thermo, template<class> class Type>
inline Foam::scalar Foam::species::thermo<Thermo, Type>::T
scalar f,
scalar p,
scalar T0,
scalar (thermo<Thermo, Type>::*F)(const scalar, const scalar) const,
scalar (thermo<Thermo, Type>::*dFdT)(const scalar, const scalar)
const,
) const
scalar Test = T0;
scalar Tnew = T0;
scalar Ttol = T0*tol_;
int iter = 0;
do
Test = Tnew;
Tnew =
(this->*limit)
(Test - ((this->*F)(p, Test) - f)/(this->*dFdT)(p, Test));
if (iter++ > maxIter_)
FatalErrorIn
"thermo<Thermo, Type>::T(scalar f, scalar T0, "
"scalar (thermo<Thermo, Type>::*F)"
"(const scalar) const, "
"scalar (thermo<Thermo, Type>::*dFdT)"
"scalar (thermo<Thermo, Type>::*limit)"
"(const scalar) const"
") const"
) << "Maximum number of iterations exceeded"
<< abort(FatalError);
} while (mag(Tnew - Test) > Ttol);
return Tnew;
It can be found the reason cause the error is "iter++ > maxIter_".Then I found the difine of maxIter :
const int Foam::species::thermo<Thermo, Type>::maxIter_ = 100;
So I make the const int Foam::species::thermo<Thermo, Type>::maxIter_ = 500,and wmake these class.Then I ran my case again,but the temperatue rise above 1365K,it still gave me the same error.At last,I make maxIter_=50000,and ran my case,it still gave the same error.
Why ?It should work after I change the value of maxIter_.However,it did not work.Can someone give me some advice?Any reply will be appreciated!
