December 29, 2013, 06:32 |
simulating two different gases
I would like to know how to simulate two different gases in same domain in compressible flow solver. I use a modified form of rhoCentralFoam. Domain is a cylindrical pipe with two internal diaphragms. I want to specify gases with different densities in the partitioned regions. I don't think it is a multi-phase flow type. The two fluids do not interact. It is just the transfer of loads that I am looking at. The gases are modeled by same eqn of state. I just want to change the density. As I post, I think about another option as to breakup the internalField into two so I can specify different initial densities. I don't know if its possible in openfoam. suggestions would be sincerely appreciated. |
December 31, 2013, 04:11 |
Hi Bernhard,
Thank u for your response. I don't have much exp using reactingFoam. Also, I am using godunov type schemes for shock capturing which i guess i cannot use in reactingFoam. Of course, i can modify it to my use. Now, I want to know if i use splitmeshRegions utility can i specify two different gases ? if yes, how to do it ? |
2D simulation for mixing two non-reacting gases | arun.mechie | FLUENT | 17 | August 3, 2016 08:31 |
Injecting Two Different Gases | ERPLCFD | FLUENT | 1 | October 12, 2013 11:21 |
Can compressibleTwoPhasesEulerFoam calculate two miscible Gases with each other? | Kenna | OpenFOAM Pre-Processing | 0 | October 10, 2013 10:32 |
Exhaust gases dispersion simulation in open atmosphere | maazz | FLUENT | 0 | June 28, 2013 11:07 |
modeling a mixture of gases | franciscotovar | CFX | 0 | October 17, 2006 12:41 |
