Problem with volSymmTensorField components
Like Tree3Likes
  • 2 Post By cedric_duprat
  • 1 Post By rvl565
Old   December 16, 2008, 08:04
Default Hi all, I've a small questi
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi all,
I've a small question about tensor components.
I'm playing with a volSymmTensorField, because it's symetric tensor, it has only 6 components.
to get the component of the tensor, I'm using this command: myTensor.component(vector::XX).
I wanted to get (with Info) the value of myTensor.component(vector::ZZ) and I had an error.
(FOAM FATAL ERROR : index out of range#0 ...)
To find the mistake, I ploted 9 components of myTensor in this order: XX, XY, XZ, YX, YY, ... to ZZ
And, I get different value the first sixth one (XX, XY, XZ, YX, YY, YZ) which is not normal. And because of that, ZZ doesn't seems to exist.
My questions are in which order are the component in a symmTensorField ? and ... is it normal to get values for (vector::XY) and (vector::YX) in a symmetric tensor?
Thanks for helping,
Cedric
cedric_duprat is offline   Reply With Quote
Old   December 16, 2008, 11:20
Default I found a part of my questions
Cedric DUPRAT
I found a part of my questions, if someone is interrested.
in a volSymmTensorField, there is only the upper triangle which means XX, XY, XZ, YY, YZ, ZZ.
and for the other part of my question, ... I just imagine that my command to get the components of the tensor is not the right one for a symmetric tensor.
Cedric
nishant.kumar and krikre like this.
Old   August 19, 2009, 13:20
Default How to plot components of Symmetric tensor?
Sven Winkler
sven is on a distinguished road
Hey Cedric,
I just saw your post and you mention, that you use the command: myTensor.component(vector::XX) to get e.g the first component of a volSymmTensorField named myTensor. I tried the same and wanted to give out this component by
Info<< myTensor.component(vector::XX)
Unfortunately I always get an error saying
XX is not a member of 'Foam::vector'
What am I doing wrong? Thanks a lot!
sven is offline   Reply With Quote
Old   August 19, 2009, 13:40
Henrik Rusche
henrik is on a distinguished road
Dear Sven,
try tensor::XX.
Henrik
henrik is offline   Reply With Quote
Old   August 20, 2009, 05:35
Flavio Galeazzo
flavio_galeazzo is on a distinguished road
I have faced the same problems with the symmTensor, in the post processing tool stressComponents.C (http://www.cfd-online.com/Forums/ope...ponents-c.html)
Where is myTensor.component(tensor::@@) should be myTensor.component(symmTensor::@@). Then the nummering of the elements is right.
flavio_galeazzo is offline   Reply With Quote
Old   June 2, 2016, 23:21
RacMat
rvl565 is on a distinguished road
Hi!
I have a similar problem and it would be great if someone could help me!
volSymmTensorField S = symm(fvc::grad(U_)); // this line is fine
volScalarField x2=S.component(symmTensor::xx); // this line is not! i tried (Tensor::xx) as well and that dosent work either
Please let me know how to access and use one of the components!
rvl565 is offline   Reply With Quote
Old   June 2, 2016, 23:29
RacMat
lol got it
volScalarField x2(S.component(symmTensor::XX));
Originally Posted by rvl565 View Post
Hi!
BruceThe likes this.
What are the UVW velocity components Nikunj FLUENT 2 January 12, 2022 12:28
to know fluctuating components R.THUNDIL KARUPPA RAJ FLUENT 1 June 29, 2005 17:30
stoke components Sara Fidelity CFD 0 May 30, 2004 11:05
stoke components Sara FLUENT 0 May 30, 2004 11:04
How to visualize the components raintung FLUENT 3 May 20, 2003 09:47
