Solution dependent mesh movement
Old   June 22, 2011, 10:50
Default Solution dependent mesh movement
Van de Leur is on a distinguished road
Dear users,
With dynamic meshing I want to make a boundary that moves depending on the flow velocity over this boundary. The movement of the boundary will then become solution dependent.
To achieve this I would like to use the velocityLaplacianFvMotionSolver.
However, the movement of a boundary in this solver is constant and read from the files 'pointMotionU' and 'cellMotionU'.
Instead of reading the displacement velocity from a file I would like to use the velocities in the domain.
The question is if the current input for velocityLaplacianFvMotionSolver.C:
pointMotionU_
IOobject
"pointMotionU",
fvMesh_.time().timeName(),
fvMesh_,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
pointMesh::New(fvMesh_)
can be replaced by something along the lines of:
pointMotionU_ = U.boundaryField()[patchi]
So far I have not been successful, does anyone have a suggestion?
Kind regards,
Kevin
Van de Leur is offline   Reply With Quote
Old   June 25, 2011, 14:41
Philippose Rajan
philippose will become famous soon enough
Hello Kevin,
A Good Evening to you :-)!
I had looked into this about two years ago, and adapted some of the common solvers (turbFoam and simpleFoam) to handle solution based motion of boundaries.
You need to search this forum with the following phrase "turbulent solver rigid body dynamics", and you will find a topic with three pages worth of discussions, and multiple downloads for solvers, and examples.
Since I have not looked into it for a long time now, you might have to make some small modifications to get it running on OpenFOAM-1.6-ext (Or maybe OpenFOAM-1.7.x)....
If you have any questions, I could try and help you out :-)!
Have a great weekend ahead!
Philippose
philippose is offline   Reply With Quote
Old   June 28, 2011, 15:30
Hey Philippose,
Thanks a lot for the reference, very useful.
I'll let you know if I have some questions, or nice results.
Regards,
Kevin
Old   September 27, 2011, 15:26
Philippose,
I've been following your advice and it helps me a lot.
Regarding the code you've written I do not fully understand the following line from the file solveForceBalance.H:
scalar calcVelocityX = calcVelocity * (aVector & dirVector1);
If I'm not mistaken aVector gives the velocity after multiplication with calcVelocity and dirVector1 gives the direction of this velocity. Mu question is, why is the directional vector also multiplied with calcVelocity?
Regards,
Kevin
Old   January 13, 2014, 07:00
Detian Liu
Detian Liu is on a distinguished road
Dear Philippose and Kevin,
I am very interesting in your great work, and I want to implement the functionality in which dynamic mesh motion is based on the velocity solution, that means if U is less than U0, the mesh will become a part of boundary, if U is large than U0, the mesh will become a part of computational demain, whether I can use the Foam you mentioned before called "turbForceFoam" to implement this functionality? Or is there some inbuilt solvers in OpenFOAM2.2.2 can achieve this goal?
Thank you in advance for the help!
Best regards,
detian
2014.1.13
Detian Liu is offline   Reply With Quote
dynamic mesh
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Radiation and miscellaneous enhancements vtk_fan OpenFOAM Running, Solving & CFD 6 February 17, 2008 23:49
how to converge the solution for fine mesh kathiravan Siemens 5 August 11, 2006 01:30
