compressibleInterFoam phase capturing
Old   February 12, 2014, 05:38
Default compressibleInterFoam phase capturing
Martin Bartonitz
mabar is on a distinguished road
Hi Foamers,
i am not totally new to Foam, but new to the compressible part of foam. So here is my case.
Its an bottle with a narrowing and a nozzle. For the initial conditions i have defined two phases (water=red, nitrogen=blue). The water will be pressed out of the bottle due the internal pressure (internal press = 52 bar, outlet press = 1 bar). The first picture shows the geometry in the YZ-plane. The water in modeled as an perfectFluid with R = 1e40, so that it is almost incompressible.
After a few milliseconds of physical calculation time a recirculation zone establishes (thats what i expected). The recirculation zone is shown in the second picture (alpha) and the third picture (u_Z).
At the bottom is the defined outlet with fixed pressure. All the rest is defined as a wall.
It seems that foam is not really consistent with the phases, because in the recirculation zone is no water but nitrogen. So if the nitrogen phase hits the outlet, the velocity rises and in the end foam aborts the simulation due to the maximum number of iterations for T. So thats clear.
How is the nitrogen phase possible? Could it come due to my setFieldsDict? Does foam fill all default faces with the following filedvalues? If so i should just change the default with the field Values.
defaultFieldValues
volScalarFieldValue alphaWater 0
volScalarFieldValue p_rgh 52e5
volScalarFieldValue p 52e5
volScalarFieldValue T 293.15
regions
boxToCell
box (-0.2 -0.2 -0.1) (0.2 0.2 0.34833);
fieldValues
volScalarFieldValue alphaWater 1
I have done an investigation with a straight pipe and exactly the same boundarys. That calculations worked just fine (no recirculation area) and i made good results.
Does anybody have an idea?
Best regards
Martin
mabar is offline   Reply With Quote
Old   February 12, 2014, 06:05
pingat is on a distinguished road
I would guess its a problem of your dynamic pressure.
The alpha also gets to negative values!?
Maybe you get some strange pressure settings, that lead to something like vacuum.
If you would post some information over your \0 files we could say more. Also a checkMesh would be helpful.
pingat is offline   Reply With Quote
Old   February 12, 2014, 06:16
Martin Bartonitz
Hi pingat,
here is the checkMesh output:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1836959
internal faces: 1810693
cells: 607942
faces per cell: 6
boundary patches: 2
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 607942
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
OUTLET 3086 3138 ok (non-closed singly connected)
CYL 23180 23232 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.0550002 -0.0549702 -0.08) (0.0550002 0.0549702 0.459)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.61615e-15 2.57493e-16 2.21697e-16) OK.
Max cell openness = 3.25416e-16 OK.
Max aspect ratio = 8.32323 OK.
Minimum face area = 1.52359e-07. Maximum face area = 1.98785e-05. Face area magnitudes OK.
Min volume = 1.7119e-10. Max volume = 2.6386e-08. Total volume = 0.00404693. Cell volumes OK.
Mesh non-orthogonality Max: 44.6657 average: 10.857
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.07194 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Here are the state files from =/
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
OUTLET
type zeroGradient;
value uniform (0 0 0);
CYL
type fixedValue;
defaultFaces
type empty;
p.org:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 52e5;
boundaryField
OUTLET
type totalPressure;
value uniform 1e5;
gamma 1;
p0 1e5;
CYL
type calculated;
value uniform 1e5;
defaultFaces
type empty;
p_rgh.org:
boundaryField
OUTLET
type totalPressure;
value uniform 1e5;//745909.451228;
gamma 1;
p0 1e5;
CYL
type fixedFluxPressure;
defaultFaces
type empty;
T.org:
dimensions [0 0 0 1 0 0 0];
internalField uniform 293.15;
boundaryField
OUTLET
type zeroGradient;
CYL
type zeroGradient;
defaultFaces
type empty;
alphaWater.org:
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
OUTLET
type zeroGradient;
CYL
type constantAlphaContactAngle;
theta0 45;
limit gradient;
value uniform 0;
defaultFaces
type fixedValue;
value 1;
I guess mut, omega, k are not that important to the problem. Its the foam version 2.2.2
Alpha doesn't get "real" negativ values, more like: Min(alpha1) = -3.83397e-22 Min(alpha2) = -4.26326e-14
Best regards
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 07:33
capturing of particles by spray (multi phase flow) latest CFX 3 June 11, 2013 08:24
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
